02-23-2016, 09:55 PM | #26 |
Re: ZZ502 died while driving. Need help troubleshooting
I figured we would see something like that if you followed up. The cam gear is likely hurt as well. The biggest issue is all of the metal that go dumped on to the cam and crank when that gear was coming apart. I hate to say it but if I were you I would just start pulling the engine out to at least inspect all the bearings and machined surfaces. That didn't happen instantly and likely slowly dropped metal into the engine which can cause a lot of damage.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-23-2016, 10:47 PM | #27 | |
I'm not really in disagreement here, But the gear on the steel Roller cam is probably OK. I agree, The metal that it made could have caused some insert damage. However I have seen many Gen 1 Vortec's & Gen 2 LT1's strip distributor gears, Haven't lost one yet after a GM melonized gear replacement, With several UOA's to prove the engine survived gear failure. If this was a flat tappet lobe failure I would be in total agreement. In the LT1 cases, They will still run after a gear failure, A couple ran without oil pressure for a little bit. I would throw a gear in it, Change the oil & filter, Drop the oil in a 1000 miles, Take a sample & send it to Blackstone Labs to get some base wear numbers. Then have a sample analyzed every oil change too see what is going on. What oil weight are you running? Stock oil pump? |
02-23-2016, 10:59 PM | #28 | |
02-23-2016, 11:02 PM | #29 |
10-4 brother.
02-24-2016, 01:06 AM | #30 |
60-66 Nut
In rereading the OP's posts it sounds like he must have bought the ZZ502 Deluxe crate engine. That package comes with a HEI distributor, which should have had the melonized gear. Not that they don't wear out, just sayin'
02-24-2016, 01:18 AM | #31 |
If that is in fact the case this is even worse.... I personally would be mad as hell if I bought a setup that was supposed to complete only to end up on a tow truck.
02-24-2016, 08:21 AM | #32 | |
