02-21-2016, 12:28 PM | #26 |
Re: engine dies in 15 minutes
You're either losing spark or you're losing fuel. Don't make it any more complex until you figure out which is the culprit.
When the thing dies, spray a spritz of carb spray or starter fluid down the carburetor. Does it try to start now ? If so, you have a fuel supply issue. If the spritz down the carb didnt cause it to try and start, pull a plug wire off and check for spark while cranking. |
02-21-2016, 01:16 PM | #27 |
When it dies look into the carb and see if the squirters are pumping fuel. Is the motor timed correctly? It could be getting hot due to poor timing and causing excessive heat that is vapor locking the fuel system. Are any fuel lines ran near the exhaust manifold?
1972 Chevy C-10, BBC, Pro-Street SWB conversion |
02-21-2016, 03:27 PM | #28 |
When I had this problem before, I changed the fuel pump and had no problem for a couple years. That's why I changed the fuel pump again.
02-21-2016, 10:12 PM | #29 |
I had the same problem, I tryed two different electric pumps and a mechanical pump and changed filters many times and it still died in about 15 or 20 miniues. I ended up pulling the tank to clean and coat it and found the filter sock on the sending unit pickup tube was plugged nearly solid and very rusty. So with a new sending unit and a clean tank she runs all day long.
02-21-2016, 10:39 PM | #30 | |
PITbut
Go spend 100 bucks and have a tech diagnose it for you.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
02-21-2016, 11:03 PM | #31 | |
[This is too subtle even with the smiley perhaps, I agree troubleshooting is a lost art sometimes]
02-21-2016, 11:47 PM | #32 |
You don't have to replace all the parts just the ones a PROPER diagnosis points to.
02-21-2016, 11:49 PM | #33 | |
02-22-2016, 12:26 AM | #34 | |
My point was that a good technician doesn't just replace parts until the thing works again. He figures out why it's not working properly and fixes the problem. Which is why I said troubleshooting is a lost art... But I wouldn't pay someone to look down the carb for me to see if fuel is shooting, or to check spark. Cover the basics at least!
02-22-2016, 12:34 AM | #35 | |
02-22-2016, 01:00 AM | #36 |
One thing I forgot mention is I have a filter before the carb with a glass housing so I could monitor the amount of fuel I was getting when I first started it compared to when it would stop running. Since its before the carb I could tell I wasn't getting fuel to the carb and knew my problem was between the pump and tank. Since its a new pump that led to the tank. Cheap and easy diagnosing that I did myself.
02-22-2016, 10:44 AM | #37 |
PITbut
Lol. I giggled. I feel you man. It should be a relatively easy diag.
02-22-2016, 12:42 PM | #38 |
With informative forums and you tube any problem you may have should be easy enough to diagnos and correct within hours not days weeks or months . Sometimes you can lead a horse to water but you can't make them drink .
Posted via Mobile Device |
02-22-2016, 01:17 PM | #39 | |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
02-22-2016, 01:49 PM | #40 |
I was watching a dyno session this week and they had a dead hole. The guy (the customer at home, not the shop or dyno guy) only put rings on seven pistons.
The exhaust port was clean as a whistle, never fired. Proof that you DO need compression, not just fuel and spark. But I doubt he loses compression after 15 minutes...
03-10-2016, 04:55 AM | #41 |
For anyone reading this thread: Had the truck towed to a mechanic highly
rated on Angie's list. He's telling me 'you can't find anyone to work on a quadrajet carb anymore." "You need a $2500 fuel injection kit" Is it really that hard to find an honest mechanic? I can simply order a rebuilt quadrajet carb for as little as $270. Where do I go to get the "screw me" sign taken off? |
03-10-2016, 05:04 AM | #42 |
Sorry guys, I forgot, this isn't dear abby.
03-10-2016, 08:00 AM | #43 |
http://www.allamericanautolongmont.com/ here is a repair shop with an A+ BBB rating in your town , Bite the bullet and drop it off . The only other best bet would be to contact some of the local car clubs and ask for some help .The fuel system in these old trucks is not rocket science .Have you ever tried to pull the sending unit in the tank ? your problems started years ago and got better when you replaced the fuel pump .You may just need to clean the fuel tank and lines ? And get rid of the glass fuel filter it's a fire hazard .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-10-2016, 08:28 AM | #44 |
Are you using a ballast resistor , or the white cloth covered wire to your coil ?
with the truck running , or key in the run position , you should have around 9 volts to the coil positive , if its 12 you may be overheating the coil , it will wear your points quickly also
03-10-2016, 08:57 PM | #45 | |
I still don't know after reading this threadif you were ever able to determine if its fuel or spark...
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-11-2016, 01:04 PM | #46 | |
You need a mechanic who specializes in pre-1972 vehicles, probably. I'm fortunate to have 3 old veterans who work from a huge rural home shop so when I can't figure it out, they do. But that's all they do - classics and old stuff. A basic Q-Jet tuneup is something a respectable tech should be able to do before falling out of bed in the morning. But not many current techs, working on modern vehicles, will know much about them. Find a good local tech. Then buy him a Christmas present at Christmas, send them a card, pay your bill promptly, and hope they live forever. Odds are they will be over 50 already, one foot on a banana peel and the other....
03-11-2016, 01:09 PM | #47 | |
PITbut
The $2500 dollar fuel injection is pretty funny. We just went through something similar. On my 71 i had a quadrajet on it. It would run great, then run like ****, then run great. My tech, who is an old timer. Completely tore it down, rebuilt it and it ran great, then started running like crap again. Turns out that the pinhole passages everywhere in the carb were getting this corrosion of some kind and i think the ethanol in the fuel wasnt helping. I slapped an edelbrock on it and never looked back. No one, not even me is going to want to rebuild your carb, but we would offer a already rebuilt unit. Slap a new carb on it and call it good. You can do it yourself and its not very expensive at $270 bucks.
03-11-2016, 03:31 PM | #48 |
So I got my truck home, carb's in pieces in a box. $300, including towing both ways. For all you who make a living at working on cars, it just got a little tougher to prove you are honest. This is a town of about 100,000 people, many mechanics. I'm looking into buying an ad in the local paper to tell people about this. No names of course, the justice system protects the guilty, not the victims. I'd like the honest mechanics to know why people may not trust them.
In Colorado, small claims court doesn't cross county lines, since I moved a few miles recently, there's no help there. Angie's list says these people are great, who bought them off? Maybe they are doing their own reviews. Since I got into this I've done more research about these people. There are horror stories about the owner, including flipping customers off in his parking lot, on Main street. There will be one less classic truck on the streets for the foreseeable future. Last edited by happy1970GMC; 03-11-2016 at 03:34 PM. Reason: add to it |
03-11-2016, 03:35 PM | #49 |
Just wanted to thank you all for your help, I'll get back to working on it sometime.
03-11-2016, 03:44 PM | #50 | |
PITbut
You cant tell me they didnt tell you there would be a diagnostic fee for shaking it down? Tell the whole story.
