03-04-2016, 09:13 PM | #1 | |
Re: A quick look at the Hickey worm gear winch
White K20 |
03-04-2016, 09:50 PM | #2 |
Jeff, It looks like you are doing some good work. I feel bad, I wish it had been in better shape. Bruce
Posted via Mobile Device |
03-04-2016, 10:14 PM | #3 | |
But hey, putting old equipment back into service is always a challenge. I am still very happy about the winch. You made me a great deal on it, I am grateful.
White K20 |
03-04-2016, 11:15 PM | #4 |
There's one big problem with all this Jeff... you won't get to have it done this weekend!
Bruce, did you have two of these before you sold one to Jeff? And if so... what else you hiding out there?! hehe
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
03-05-2016, 07:14 AM | #5 |
Dazza, i did have one. I bought it from Blazerman in Kansas City, Missouri. Winch only, no acessories. Not long ago i found this one on the internet. It had everthing, except the owners manual. The owner agreed to ship, so i paid to have the acessories shipped. I came to this forum asking for help with a Hickey winch in CA, with the intent of selling it to a board member that was in the area or was willing to pay $$ for shipping. Bruce
Posted via Mobile Device Last edited by BLT gmc; 03-05-2016 at 09:09 AM. |
03-05-2016, 03:54 PM | #6 |
03-06-2016, 01:45 AM | #7 |
03-06-2016, 11:26 PM | #8 |
Ya, I tried to post some pics from my cell phone earlier today. My phone was being a jerk. I'll post some next week.
White K20 |
03-06-2016, 10:16 PM | #9 |
ok, all up and in there.
Jeff, not until I was looking at mine today did it hit me that you asked about me having a skid plate... yes I do, not installed yet but there is a side view shot of it in my other post mentioned above. If you need measurements let me know. I'm back to my main computer so will be having a look through my other photos. I think I may have bearing/seal qty & part #'s too if needed.
03-06-2016, 11:38 PM | #10 | |
The front of your truck looks clean with the fairlead on the bumper. I got the bearings in the mail yesterday. So, it looks like, so far, all I need is seals, gaskets, and bearings. The bushings looked real good. So, as I clean the parts I can make a decision on the motor and motor gear. Also, my old wire rope looks great. I pulled the whole line, no kinks or fraying. So I may keep it for a while and hunt for some synthetic later on.
White K20 |
03-07-2016, 12:32 AM | #11 |
That picture is my truck, same truck/winch just not taken apart, cleaned and rebuilt. It's just a skid plate, mounts at bottom of fairlead, rolls under the winch and goes back to the rear winch cross bracket.
Bad picture (currently looking for another I have) but it's the gray plate at the top left...
03-07-2016, 03:13 AM | #12 |
Hey Jeff, cool read on the Hickey worm gear winch? Looks like you're making real good progress. One question though, did you get your motor issue sorted out? If not, look around for a motor rebuilder. They can rewind the motors, install new brushes, bearings and the like. Being in LA, there should be at least a couple of places. Better than trying to make something work?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
03-07-2016, 07:02 PM | #13 |
Jeff, I found this reminder of my issues with that gear! I think that's the puller that was able to finally pull it off!
03-07-2016, 09:48 PM | #14 | |
Plus check out the 10 spline, a possible design flaw may be why they ditched it for the smooth shaft, from what I'm looking at now anyway. In the following pics check out the 10 spline. How do you seal the shaft? Exactly, that's why I think they had two seals stacked, one to keep out most oil and one shoved up against the motor housing to get a bead on the small amount of smooth shaft. So, I think I will get a smooth shaft motor and figure out how to retrofit for a newer gear for a smooth shaft motor and still use a 3/4" seal on the shaft and get a good seal right at the case. Plus, the new design is to use a smooth bore gear with a key and set screw, there is a collar on the motor side of the gear that sticks through the transfer case; and the new seal is larger and seals at the gear collar. Again, some room for small leakage as the seal is not made at the shaft and some small amounts of oil could make it between the inner gear bore and the shaft and out to the motor when it's spinning. So my Idea is to maybe use the old style small seal at the shaft, and retool a new style smooth inner bore gear so the collars stops short of the inner side of the transfer. I will post more pics when I get the new style smooth inner bore gear, and post if it does or does not work and why. Anyhow If it work's I will have a good cheap solution for anyone in the future.
White K20 |
03-08-2016, 09:34 AM | #15 |
Dazza, how were you able to get the mounts on top of the lower frame rail? Bruce
03-09-2016, 11:06 PM | #16 |
New gear came in the mail today. Good news on the gear, it has a seal installed on the inner bore. So, disregard my verbiage in post #50 where I say there is no seal on inner gear bore to shaft. I was happy to find I was wrong. No good specs on the gear when I bought it.
When I got the gear it became apparent what to do, though you do have two choices. 1) Surface collar of new gear down to same length as original gear and use old style small shaft seal only. 2) Bore the case to accommodate the new bigger size seal. I ran the case down to the machine shop this evening and had the case milled to 1.745 (just shy of 1 3/4". The new seal is hard rubber and not metal cased, so I opted for a bit tighter tolerance. So now I will order the Western Motors 8933 motor. The gear is Pierce Sales Motor Drive Gear (PS654) seal is motor seal (PS654) and woodruff key (PS654) So the cost to get off the old 10 spline motor:= $30 for the new gear and $30 for the case milling. Plus some change for the seal and woof woof key. So about $140 to upgrade off the 10 spline. So the price of the 8933 is $83(free shipping) plus the $60 for gear and mill work. Try to buy a 10 spline for that! Here's some pics. New and Old gears. New gear had shaft seal installed already. New and old gears with seals. The old gear is shorter and stops at the transfer so the seal is same diameter as the gear. The new gear is longer and has a fatter collar the runs through the case. Case milled for new bigger seal. Inside view with big seal and new gear.
White K20 |
11-09-2017, 05:22 PM | #17 | |
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
11-09-2017, 07:07 PM | #18 | |
Anyhow, if you have access to a machine shop, and if you have to replace the motor, I would get the large collar gear and seal kit and give it a good look over. I didn't want to pay to have my motor fixed, and the only new one I found was north of $300 (a kings ransom for a simple motor like this). So I went with the cheap maintainable route. I'm not calling my decision good or bad, just my decision when I was at the motor/gear crossroad! In the end I got the 10 spline motor working, go figure! I gave it to Bruce. You can have my old gear if you want it, pretty sure I still have it. Might be in a bit better shape than yours, not sure. I can dig it up an photo if your interested. j
White K20 |
11-10-2017, 08:33 AM | #19 | |
03-11-2016, 10:06 PM | #20 |
Just back in town...
Bruce, I found the easiest way to maneuver this or the sidewinder was to loosely mount the the brackets where I wanted them to be, then I use a hydraulic cart that I'm lucky enough to have available to me to raise the winch into place. With this winch set down having the gear box facing up, I slowly raise the cart up and as it contacts the brackets, it pretty much rolls forward into place. For future reference, I tried both front and rear brackets on top of lower frame rail but could not get it to align properly. The only success I had was with front bracket on top and rear underneath. I'm content with how secure it feels and if I thought I'd be doing some serious pulling with it, I'd probably give it a few hits with the welder, for CDO sake anyways! Jeff, It's been a few days since you've posted, looks like you have it sorted. Is it mounted yet?
03-11-2016, 10:31 PM | #21 | |
Also, I am happy with under frame mount. The 7/16 grade 8 bolts are fine. Initially I tried to fit it inside the rails because I assumed that's where it mounted. But, if your putting massive force on the bolts during winching operations, I don't think over or under matters. Just my thoughts, and I'm feeling good about under mounting. I'll post more pics when I get the motor so the smooth shaft change over is verified and put to rest for future reference.
White K20 |
03-12-2016, 03:19 AM | #22 |
I've also started going through my photos and posting for reference if anybody needs. So far, np205, sm465, and winch. A lot of duplicates but different angles just in case, I've often found what I'm looking for in the background of a picture that I didn't even know was there!
---> Hickey Winch
03-14-2016, 10:19 PM | #23 |
OK, I got the new smooth shaft motor in the mail today. I ran out this evening to see if it fit. I will have to admit the waiting has been a bit nerve wracking for me being that I ran out last week and had the case milled based on the gear alone.
But, the motor fits fine with the gear, now I can complete clean up and assemble. A relief. Here's some pics. I also included the two electric motor specs from Western motor. Just for easy reference for the next guy or gal. Everything fit... so far The old 10 spline and new smooth shaft Here's the specs for both motor form Western Motor. Also, I want to point out that the raised ring diameter(3") and the shaft length(1-7/8") is same for the 10 spline... even though it's not stated on the MBJ-4301 spec.
White K20 Last edited by jeffahart; 03-14-2016 at 10:30 PM. Reason: Because I'm lame and hit submit instead of Attach Image |
03-14-2016, 10:33 PM | #24 | |
White K20 |
03-15-2016, 12:17 AM | #25 |
Excellent, nice to hear.
You received that motor quick! I'll have to make a note in regards to Western Motor, I had never heard of them until now. I've been looking for a good solenoid location under my hood and keep thinking of your compact setup...
