Old 02-23-2016, 06:15 PM   #26
donandal
Re: Plus Five
This is where we are headed....
Just got this photo today
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 02-23-2016, 06:21 PM   #27
Papabill
Re: Plus Five
I really like where you are going with this. Great fab skills and hope you keep updating your progress for us to follow along.
Papabill
Papabill is offline   Reply With Quote
Old 02-23-2016, 06:53 PM   #28
Big Daddy Bear
Big Daddy Bear's Avatar
Re: Plus Five
Beautiful color!!
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 02-23-2016, 07:54 PM   #29
dug224
dug224's Avatar
Re: Plus Five
Impressive. Need a lot of pictures!!!
dug224 is offline   Reply With Quote
Old 02-24-2016, 02:36 PM   #30
donandal
Re: Plus Five
OK,
I'm going to jump around a little.
Eventually I'll try to cover everything.
The rear end is simple. New leaf springs from Eaton Detroit.
3" drop and softer. They have the specs for the original springs.
Bilstein shocks on mounts that I made.
Late 70's camaro/firebird rear end. Sway bar setup I made
using mid 90's camaro sway bar.
53 Chevy Pickup
Old 02-24-2016, 02:52 PM   #31
donandal
Re: Plus Five
The rear end was reworked by a local shop. New gears ( 3;42 ) and
new eaton posi and new bearings and seals etc. Brushed on tractor
enamel after they were done. They dipped it and it was perfectly clean.
The brakes are 1998 to 2002 Camaro that have parking brake thru the
disc type setup. I made the brackets and backing plates.
53 Chevy Pickup
Old 02-24-2016, 03:02 PM   #32
donandal
Re: Plus Five
The cab was extended 5 inches so the frame and running boards were
also extended five inches.
I did the frame extension about under the middle of the cab.
53 Chevy Pickup
Old 02-24-2016, 03:28 PM   #33
donandal
Re: Plus Five
the running boards needed 5 inch extensions, plus a rework
of the curved area that meets the rear fender.
I also reworked the bottom braces for strength and
to allow easier installation.
53 Chevy Pickup
Old 02-24-2016, 05:58 PM   #34
donandal
Re: Plus Five
this sequence of photos shows the frame after paint...
53 Chevy Pickup
Old 02-24-2016, 06:11 PM   #35
donandal
Re: Plus Five
one more piece of color
53 Chevy Pickup
Old 02-24-2016, 11:17 PM   #36
BIGglaSS
BIGglaSS's Avatar
Re: Plus Five
Nice work! I'm diggin' that front end.
BIGglaSS is offline   Reply With Quote
Old 02-24-2016, 11:26 PM   #37
Advanced Design
Advanced Design's Avatar
Re: Plus Five
Very nice details with the body and chassis. The caliper brackets had to take some time to figure out.
The engine mounts on the frame are interesting too. Will they fit a factory engine mount?
Advanced Design is offline   Reply With Quote
Old 02-25-2016, 12:50 AM   #38
torchlight
torchlight's Avatar
Re: Plus Five
What's the details on your paint color? I think it looks amazing, but I might be a bit biased - I love red like that!
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 02-25-2016, 11:07 AM   #39
Coach529
Coach529's Avatar
Re: Plus Five
Unreal metal work...........looks great!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-25-2016, 03:05 PM   #40
donandal
Re: Plus Five
The engine mounts I used are a corvette type I guess. I ordered them on
the recommendation of the Pace Performance gentleman that sold me
my connect and cruise package.
He said they would be easy to use, and he was right. I just made up those
angle brackets and bolted them thru sleeves that I welded into the boxed
frame area.
53 Chevy Pickup
Old 02-25-2016, 03:11 PM   #41
donandal
Re: Plus Five
It is a Ford color... Ruby Red 2012 - 2017
interior color is a Lexus color...but interior is finished with FLAT clear.
Satin cashmere.
53 Chevy Pickup
Old 02-25-2016, 03:34 PM   #42
donandal
Re: Plus Five
The real work was finding rotors and calipers with the right bolt pattern that
have a parking brake thru the disc. I like that style. I spent a lot of time
on line looking at specs and dimensions. Brakewarehose.com had good info.
Making the bracket was pretty straight forward. I made a pattern from 1/16th
inch aluminum sheet. I used two driver side so I could stagger the mount, one forward, one back. That way I could stagger the shocks to control wheel hop.
53 Chevy Pickup
Old 02-25-2016, 04:06 PM   #43
torchlight
torchlight's Avatar
Re: Plus Five
Satin cashmere.
Wow, that's pretty crazy. Ford Ruby Red was one of the top 3 choices for my project - I ultimately chose a different color that was real close, but two-stage only. But that Ford color is incredible - great choice!
Here's a quick shot of my hood to compare:
Also crazy because for a time I was considering the Lexus Satin Cashmere for my accent color. You have great taste. Let's get these trucks together at a car show someday!
Old 02-25-2016, 04:25 PM   #44
donandal
Re: Plus Five
I've read your thread a dozen times..
you went with the Mitsubishi red didn't you?
I like that color too.
great minds indeed...
53 Chevy Pickup
Old 02-25-2016, 04:48 PM   #45
torchlight
torchlight's Avatar
Re: Plus Five
Yep, exactly - Mitsubishi Ultra Red Pearl. We did put some additional metallic into the paint for some extra "pop" in the sun, but the color works pretty well even with the stock mix. AD trucks look so good in red!
Old 02-25-2016, 05:09 PM   #46
wheelbarrow
Thumbs up Re: Plus Five
Looks Awesome! Your metal works looks outstanding!
wheelbarrow is offline   Reply With Quote
Old 02-25-2016, 05:15 PM   #47
donandal
Re: Plus Five
the front suspension is corvette C4
sway bar ends I machined into the original C4 sway bar after I
cut the ends off. I turned the diameter to 1 inch. Original seemed
way too stiff.
I made the arms and the brackets for the A-Arm, and found Ford F150
sway links at Advanced Auto. Bushings were also from Advanced.
the steering rack bracket on the cross member I modified to unbolt to
allow easier servicing of the rack and pinion. It can now be dropped out
the bottom under the engine.
53 Chevy Pickup
Old 02-25-2016, 05:22 PM   #48
donandal
Re: Plus Five
more,
53 Chevy Pickup
Old 02-25-2016, 05:35 PM   #49
donandal
Re: Plus Five
the gas tank was taken out of the cab and moved to the rear.
It is a stainless steel 1949 chevy car tank from "Tanks", and will have
a fill thru the driver side rear fender.
It came set up for LS engine with fuel pump and sending unit flanges.
I made the stainless straps and mounts, as well as the filler door and recess
fill and drain pocket and welded it to the fender.
53 Chevy Pickup
Old 02-25-2016, 05:41 PM   #50
donandal
Re: Plus Five
some more,
53 Chevy Pickup
