Re: Farm truck refresh
Well looks like I'm not getting a pulse signal to the injectors (at least as best as I can tell).
84 K5 6.2 Diesel/700R4 (Project on hold) 84 K10 Extended Cab 350TBI/TH350 98 C3500HD 6.5/NV4500 Dump 03 Silverado 2500HD 6.6/Allison 07 Ford Escape Hybrid (Commuter) 15 Chevy Impala |
Got a noid light to test the injector pulse and confirmed that is the problem. I guess that means my ECM is bad...
Harness is a new swap harness, ECM has power as confirmed by the check engine light.
the injectors pulse so fast that you really can't verify if you are getting the electrical pulse without a noid light as previously mentioned.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
After doing more reading I see that the injectors won't pulse unless there is spark. I'll start chasing the spark side and see where that leads...
