05-03-2016, 01:07 PM | #26 |
Old member
Re: My super-duper fan controller magic box!
Hart_Rod ,
Even with the AC running?
05-03-2016, 10:36 PM | #27 |
Would still Need the trinity, not sure the GM LS crate package is able to shut the fans off at a set speed. That is something I will have to look into.
05-04-2016, 07:51 AM | #28 |
I'll have to double check it this evening, but I think that is an option.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-04-2016, 08:20 AM | #29 |
Old member
Please LMK please.
05-04-2016, 09:28 AM | #30 |
I will tag along here too, I did not find any options for it on hptuners however I am not as in the know so to speak on tuning as many of these guys on here.
All I have been able to do with the AC on mine is "bump" the idle up when it is on. I do believe it is an option to turn the fans on when it see the AC signal I have not switched that on but may give it a try. Like stated earlier I don't think fans are necessary when driving down the highway and them engine temps don't require the fans. So far if I am moving I don't require the fans.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
05-04-2016, 09:37 AM | #31 |
I am also not seeing any selection in HP tuners to deactivate the fan at a set road speed. Maybe I am missing something.
I also do not know if the Crate Engine controller will allow for an A/C input like many of the aftermarket controllers. Meaning these controllers cannot control the A/C clutch/Fans like in a factory vehicle. I was under the impression the engine control in this case is load based.... The engine sees an additional load on the engine due to RPM drop and compensates accordingly. |
05-04-2016, 10:04 AM | #32 |
Old member
The fans are not needed at all on mine if the AC isn't on. If I cut the AC on and just idling the high side of the AC goes off scale. I need the fan on @ idle but not at speed.
I don't want a bunch of switches to turn on/off all the time. I would like to make it simple if possible along with current setup.
05-04-2016, 08:11 PM | #33 |
Here's a snapshot of the table I was talking about. Under "Running Conditions" -> AC fans disable speed, you can choose the MPH in which to shut the fans off.
05-04-2016, 08:23 PM | #34 |
Old member
OK, but I can't see it! It's to small.
05-04-2016, 08:27 PM | #35 |
05-04-2016, 08:29 PM | #36 |
Old member
05-04-2016, 08:32 PM | #37 |
05-04-2016, 08:53 PM | #38 |
Old member
Thanks Hart_Rod,
I'm going to try and see if my tuner can do anything with it.
05-04-2016, 09:18 PM | #39 |
Hey that's great. Not sure what engine you are running Heart but the new E-Rod or GMPP creat engines do not use these tables.
There may be a way to do it but these computer are not that simple when it come to on off temps either. Posted via Mobile Device |
05-04-2016, 09:57 PM | #40 | |
Does the E-rod use an E67 or an E38 computer?
05-04-2016, 10:14 PM | #41 |
05-04-2016, 10:17 PM | #42 |
I have a Excel spreadsheet I got off of HPTuners that helps you set up your fan on/off temps for the E67 and E38. Let me know if you want it.
05-05-2016, 06:08 AM | #43 | |
I will tAke you up on that. I Kind of get how to set up the dual fan control but it is still A little confusing. It one of those tings where you understand it, come back to it 3 Days later and you have to relearn it all over again.... The more you do it the easier it becomes I guess. |
05-05-2016, 09:07 AM | #44 | |
http://www.hptuners.com/forum/showth...gs-Spreadsheet
05-05-2016, 05:27 PM | #45 |
Rob, mine does not look like that. It is an older swap I did about 11 years ago. it uses a "322" computer that was upgraded if you will to a custom os for my 2 bar speed density. I have HP tuners pro and don't have those fields.
05-05-2016, 06:57 PM | #46 |
What year is your computer? Does it have red/blue or blue/green connectors?
05-05-2016, 07:06 PM | #47 |
Well yours looks simple enough to get the dual fans on/off but again it does not look like there any way of shutting them down at a set Speed.
05-05-2016, 09:36 PM | #48 |
Rob it's a 2001 or 02. It's the red and blue connector. The electric fans work as expected with the temps but no options for AC stuff. Not a biggie but would be nice to have it.
Yes it's simple and works
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" Last edited by Custom 68; 05-06-2016 at 02:47 PM. |
