09-29-2016, 12:10 AM | #26 |
Re: Old Roy
Cool picture....I went back and saw the color on the SPID label....my mistake...I think maybe it's the same color used on the '69 Camaro and called Burnished Brown in that application.
I like the name you chose for the truck...I can't help but think about the brand of dog food sold at Walmart and picked up by Eddie on Christmas Vacation lol
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
09-29-2016, 05:58 AM | #27 |
Re: Old Roy
Great story. You write well. Last photo is an amazing transformation. You ever get to the rest of the engine components to make it run better?
09-29-2016, 07:07 AM | #28 | |
Re: Old Roy
Thanks. Yes, the carb rebuild helped a lot, but it wasn't until replacing the spark plugs that it really came to life. It runs very good now.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
09-29-2016, 09:16 AM | #29 |
Re: Old Roy
I'm amazed at how nice you got that paint to look!
1972 C/10 Cheyenne, Daily Driver. SOLD 1978 GMC K15 High Sierra. |
09-29-2016, 09:33 AM | #30 |
Re: Old Roy
Old Roy is looking great .
10-02-2016, 10:12 AM | #31 |
Re: Old Roy
Good news. I'm happy for you.
10-02-2016, 12:12 PM | #32 |
Re: Old Roy
Man! I can't get over how your paint turned out!! Truck really looks amazing, can't wait t see what you're up to next.
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
10-02-2016, 11:22 PM | #33 |
Re: Old Roy
Thanks for all of the positive comments. Small update... Got a set of stainless steel hubcaps. Still have to repaint the bowtie to blue, but they make a nice addition to the truck as is. Here's a pic of it while I was out picking up a new water-softener for the house this weekend.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 Last edited by saxart; 08-13-2017 at 10:59 PM. |
10-03-2016, 07:43 PM | #34 |
Re: Old Roy
Wow...all I can say...
10-08-2016, 08:59 AM | #35 |
Re: Old Roy
This is a great truck and I love what you are doing with it. It is amazing the transformation that can be had just by doing the basics. What are your plans for the future?
-Richard
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
10-08-2016, 09:43 PM | #36 |
Re: Old Roy
Thanks for all of the compliments guys. That's the stuff that makes this forum great.
Richard- Plans for the truck are just to keep getting it back to where it was when it was in good working condition, with minor updates. I did pick up a set of the "unobtanium" 6-lug 8" wide rims, so a sand-blast and repaint is the next step. Here is a pic from today, doing a little work around the place today moving a trailer. It was a beautiful fall day!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 Last edited by saxart; 08-13-2017 at 11:01 PM. |
12-31-2016, 11:01 AM | #37 |
Re: Old Roy
Finally had some time to work on Old Roy, so I thought an update would be in order.
Last weekend I pulled the grill and gave it the "oven cleaner treatment". It's going to get some of the dents hammered out, polished, black accents repainted, then reinstalled. It will never be perfect, but should look better than it was. More on that later. Here is the oven cleaner doing it's job... Yesterday I spent a few hours pulling the front clip. The engine and transmission (4-speed stick) will need to be degreased, then the engine will be getting an entire new gasket set (at the very least). After that the engine bay is going to be detailed, then the heater box/core reinstalled. I was home alone, so I had to get some "machinery" involved to get the clip removed: Here's how it's sitting as of right now. Now that the clip is removed, I plan on doing a compression test and leak down test on the engine, then pulling it and beginning the clean up/regasket process. Oh, and I also need to either rebuild the front end (control arm bushings), or swap in a newer (disk brake) cross-member.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 Last edited by saxart; 08-13-2017 at 11:07 PM. |
12-31-2016, 01:58 PM | #38 |
Re: Old Roy
Nice work....you don't mess around, do 'ya?
12-31-2016, 11:48 PM | #39 |
Re: Old Roy
I'll take that as a compliment...
Got a few minutes to run a compression test on the engine before it gets yanked it out. For a truck that's just going to be run as a weekend shop-truck, I'm more than happy with those numbers!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 Last edited by saxart; 08-13-2017 at 11:02 PM. |
01-01-2017, 01:17 AM | #40 |
Re: Old Roy
No doubt...I'm sure you're pretty pleased...this is really turning into a nice build up/freshening up! Makes you wonder how a truck like this gets pushed off into the background!
01-01-2017, 01:41 AM | #41 |
Re: Old Roy
A thought on the front suspension, while I wait for the clock to move to 2017....if you swap that front suspension to disk, which is good thinking, you will end up with 5 lug wheels....not sure if that's a issue or not. There are some places that have disk brake conversions that let you keep the 6 lug wheels...I think Jim Carters is one if I remember correctly. It's totally doable because a friend did the same swap on a '70. He picked up a complete front suspension from a mid 80's truck and got a 12 bolt rear from a '71-'72 half ton Chevy so the rear wheels matched...worked great and looked just like it belonged there.
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 01-01-2017 at 01:52 AM. |
01-07-2017, 10:33 PM | #42 |
Re: Old Roy
Rustytruck50-
Thanks for the thoughts. I do appreciate them! I haven't decided what I'm doing with that part of it yet. Time will tell... A bit of an update.... It was -5 deg out when I woke up this morning, so I figured it would be a great day to play in the garage. LOL Big things happened today! I'll let the pics speak. Got the green work horse out again for little assistance. Took the trans out as well. Ugh... Could own a grease factory with this stuff! Not going for a Sunday cruise for quite awhile...
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 Last edited by saxart; 08-13-2017 at 11:15 PM. |
01-08-2017, 10:17 PM | #43 |
Re: Old Roy
Nice progress! The PO won't believe it's the same truck.
Btw...kudos for your work ethic...you're a much better person than me for going out in -5 degree weather to do that job!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 01-08-2017 at 10:24 PM. |
02-04-2017, 10:24 PM | #44 |
Re: Old Roy
subscribed .......cool brrrrrr makeover great time to get in the garage
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-05-2017, 07:51 AM | #45 |
Re: Old Roy
So how is Old Roy coming along ? Any update pics on that motor yet ?
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
02-05-2017, 10:58 AM | #46 |
Re: Old Roy
I like where you are going with this truck. Keep the updates coming.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
02-05-2017, 05:41 PM | #47 | |
Re: Old Roy
http://67-72chevytrucks.com/vboard/s...06#post7849406 It's Crate Engine time!
02-11-2017, 09:48 AM | #48 |
Re: Old Roy
I followed the link in your sig from the crate engine thread. I like what you're doing with Roy. The seat sure turned out nice!
Romans 10:9 - The Truth |
02-21-2017, 08:15 AM | #49 |
Re: Old Roy
More updates...
Rockauto shipped me some front end parts. BTW... Just so you know, you can rebuild your ENTIRE (drum brake) front end for $238 with shipping. So I got the A-arms removed.. One of them was a bit rusty. (used replacement is on the way) So I got the cross shafts removed, and sand blasted and acid washed the remaining 3 arms since it was freakishly warm here this past weekend. Primer... Paint... and some POR-15 on the frame... Then THIS happened! Stay tuned, more to come...
02-21-2017, 08:22 AM | #50 |
Re: Old Roy
Let the fun begin .
