Old 07-23-2016, 12:40 AM   #26
1966c10LS
Re: 1966 C10 Short Stepside LS Conversion
Frame is back from the powder coating. Ready to be put back together.
1966c10LS is offline   Reply With Quote
Old 10-12-2016, 02:08 AM   #27
1966c10LS
A few more pictures. Its starting to come together.
Old 10-13-2016, 12:05 AM   #28
Captainfab
60-66 Nut
Looks good
I haven't heard back from Chad since I got back from vacation about picking up a steering box adapter plate. I don't remember if he wanted a booster bracket too.
Old 10-13-2016, 04:15 PM   #29
thepartsguy
thepartsguy's Avatar
What size tires are u running?
63 C10
65 Chevy Custom Cab w/ Big Back Window
66 C30
72 skylark w/ 454
65 K10
May the bridges I burn light the way....
thepartsguy is offline   Reply With Quote
Old 10-13-2016, 05:50 PM   #30
chad64chevy
chad64chevy's Avatar
wow, now that's an update! what the hp numbers you will get with the supercharger? i'm thinking of a turbo but the supercharger are nice too!! will it clear the inner fender??
chad64chevy is offline   Reply With Quote
Old 10-14-2016, 02:12 AM   #31
1966c10LS
I will be putting some Budnik 20" wheels on it. 235/45R 20's front. 335/30R20's rear.
Old 10-14-2016, 02:51 AM   #32
1966c10LS
Thanks, I am happy with how the truck is coming together. Chad at ESDC of Spokane is putting it together. When it is together we will run the numbers on his Dyno. The engine has a few upgrades, we are hoping for some pretty good numbers when we run it.
We are going to have to do some work on the inner fender on that side to make everything work.
Old 10-14-2016, 02:54 AM   #33
1966c10LS
I will be putting Budnik 20" wheels on it. 235/45R20 on the front. 335/30R20 on the rear.
Old 10-14-2016, 03:18 AM   #34
1966c10LS
Some more progress. Here is the pictures.
Old 10-15-2016, 03:17 PM   #35
Notch1988
Notch1988's Avatar
Looking good, keep the updates coming.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 10-15-2016, 08:28 PM   #36
siggyfreud
siggyfreud's Avatar
Awesome build! Just stumbled upon it. Did you have to notch the frame for that PS to clear? Looks close!
siggyfreud is offline   Reply With Quote
Old 10-16-2016, 11:27 PM   #37
1966c10LS
We did a c-notch for the rear end only. We are updating the steering to early 70's to fit with the power steering with the LS. Everything is tight but clearances are there so far.
Old 10-16-2016, 11:39 PM   #38
1966c10LS
We put the font fenders and bed on so we could measure wheel sizes. Ordered them this week. 6 weeks to tires and wheels!
Old 02-15-2017, 01:24 AM   #39
1966c10LS
Latest pictures. Wheels came in, truck is coming together.
Old 02-15-2017, 01:42 AM   #40
1966c10LS
A few more pictures
Old 02-15-2017, 01:59 AM   #41
1966c10LS
I would like some input from those of you that have installed LS motors in your C10 trucks. I will need to install the wiring harness soon, I am wondering what instrument clusters you have used. I am wanting to use the stock instrument cluster or possibly use a cluster from a 2002 truck if that is possible. Have any of you that have done this got pictures you would share and what worked best for you. BTW I'm not going with Dakota Digital, just my preference.
Old 02-15-2017, 10:28 AM   #42
reaper71
reaper71's Avatar
This may not be the direction your going for, but I use Speedhut Gauges in all my builds (6th set so far) They are 100% fully customizable I.E. back light,font,tick style,bezel,pointer color face color etc.
The speedo is ava. in GPS so NO cable ran to the transmission! and the gauges can be programmed to use with any sending unit on the market!
Also on speedo....60ft time,1/4 mile time,direction,recorded top speed,and elevation.
check them out for reference.
The pic below was from Blakes build on a 67 GMC.
Mark.
reaper71 is offline   Reply With Quote
Old 02-15-2017, 10:59 AM   #43
1966c10LS
Hey thanks! I will look into them.
Old 02-15-2017, 01:00 PM   #44
scoot_mcgrute
I'm going with the factory gauges for my LS swap I'm working on. I'll adapt the factory sending units to the LS, should be pretty straightforward from what I've seen/heard.
Oil pressure will be the mechanical gauge and the tube will plug in to the factory LS sender position. I'll need an adapter I'm sure but I haven't looked that far into it yet.
For the temp gauge, there is a plug on the front of the head that is M10 threads so I will either modify the plug to take NPT threads or find an adapter that will get me where I need to go.
Love the progress you've got going on!
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 02-15-2017, 10:48 PM   #45
1966c10LS
Thanks, I really want to just keep the stock cluster. Everytime I find something I think I would like better I come back to the stock dash.
Old 02-16-2017, 11:45 AM   #46
scoot_mcgrute
Just found this for the temp sender. It'll go in the port on the passenger side head at the front. There should be an allen head plug in there now.
https://www.amazon.com/Engine-Adapte.../dp/B015NG418C
1966 Army Truck
Old 02-16-2017, 07:26 PM   #47
jweb
jweb's Avatar
I agree , that's what I did on my '51 and plan to do the same on my '64 suburban. It was pretty simple and it's hard to beat the factory look. I got oil pressure from the block off plate near the oil filter and drilled and tapped the M10 hole in the head for the coolant sensor. If you are using a modern transmission the Dakota Digital ECD-100 will convert the signal for the speedometer.
jweb is offline   Reply With Quote
