11-26-2016, 09:14 PM | #26 |
Re: 1969 LWB frame for cuts
Would you please post close up pictures of the area where coil springs mount (bottom and inside rail)on the rear sections of frame rails.
David |
11-26-2016, 09:16 PM | #27 |
Also,include price for rear frame rail sections.
David |
11-26-2016, 10:08 PM | #28 | |
Equal opportunity joke ofender
Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
11-27-2016, 02:16 PM | #29 |
I need from axle bump stop to 2nd bed mount,but would consider the whole length of rear section IF the price is right. The whole length would require 2 less weld joints.
David |
11-27-2016, 02:26 PM | #30 | |
I think i can UPS up to 108" long on the frame rails but I am going to need your complete shipping address to determine exact cost. PM it to me. The online calculator does not come out accurate on things of this nature. 108" would put you just ahead of the trailing arm cross member all the way to the rear of the frame. All of the body mounts have already sold but I do still have the bump stops if you need them. Let me know exactly what you want then I can determine shipping cost. Once I know the shipping I can give you a combined rate for everything. Richard .
11-27-2016, 02:27 PM | #31 |
more pics
11-27-2016, 02:28 PM | #32 |
Last 4
11-27-2016, 04:12 PM | #33 | |
Look at the frame rail picture and see if I have marks in correct areas. Just the UPS shipping is $130 if you want both frame rails cut at 108" approx 100 lbs If you want it cut at the 64" to the 96" mark shipping is about $55 approx. 60# Anything else and I will have to cut it 1st so I can get closer correct weights Also attached pictures of the fish plates they only weigh about 5lbs so should be able to slide them inside the frame rails with no problem. both frame rails and fish plates would add $100 to whatever length you choose. I will band them together and wrap with cardboard to ship. LMK Richard EDIT: I just realized I marked the wrong side of the cab mount holes for 96". It should be on the left side of the holes as looking at the picture .
11-27-2016, 10:06 PM | #34 |
I need a piece of frame where the power steering box mounts. Here is a pic with the cut lines. Do you still have this section left?
11-27-2016, 10:49 PM | #35 | |
David |
11-27-2016, 11:06 PM | #36 | |
Richard
11-27-2016, 11:10 PM | #37 |
11-27-2016, 11:36 PM | #38 | |
David |
11-27-2016, 11:40 PM | #39 |
It was to give you shipping address. You answered shipping cost in this thread. I will send again to make sure shipping cost is correct for my address.
David |
11-28-2016, 07:55 AM | #40 | |
I sent you a pm on your question about the upper coil mounts
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. Last edited by richard2717; 11-28-2016 at 08:01 AM. |
11-28-2016, 05:23 PM | #41 | |
11-28-2016, 11:51 PM | #42 |
Rocket3 is out on the frame parts so they are all still available
12-04-2016, 09:17 AM | #43 |
I'm not getting any help locally so I will do the $30 + shipping for this section. Please PM what I need to do in order to pay you and I will send you my address. Here is a shot of the area that I need:
12-04-2016, 09:58 AM | #44 |
Pm sent
12-04-2016, 12:55 PM | #45 | |
Thanks Richard
01-14-2017, 10:29 AM | #46 |
Still have some pcs & cross members left
03-11-2017, 07:59 AM | #47 |
Ttt
03-23-2017, 03:40 PM | #48 |
Ttt
04-15-2017, 01:23 PM | #49 |
track bar & mounts, lower shock mounts, coil spring cross member and related brackets all sold local today.
Still have frame rail cuts and some other pcs available
04-27-2017, 06:26 PM | #50 |
looking to buy trans crossmember if its for the three speed trans
