11-26-2016, 06:35 PM | #26 | |
Re: First time truck buyer questions
11-26-2016, 06:45 PM | #27 |
so this is another truck I'm looking at.. is this more than surface rust?
I know some of the guys on here said rust is a deal breaker.. does that mean surface rust? |
11-26-2016, 07:20 PM | #28 |
To western folk surface rust is the kind that turns your hand orange when you run your hand over it. To us rust belters it means small flakes come off but you can't quite punch a screw driver through it yet. To me it looks like the sheetmetal has advanced surface rust where you get some flakes of metal coming off but no holes and you can't punch a screw driver through. If you sand blast and paint you can save the sheetmetal that's there in the pics. Don't worry about the rust pictured on the frame rails, as long as the rest of the frame is no worse than pictured it's fine. Judging by those pics I'd say the rest of the truck is probably really solid, at worst maybe the basics like cab corners and outer rockers might need replacing. Definitely worth a closer look.
You did notice in one of the pics a body bushings is missing though right? Not a deal breaker just something that's needs to be addressed. |
11-26-2016, 08:01 PM | #29 | |
11-26-2016, 09:56 PM | #30 |
I still think it's worth a closer look. Be sure to check around where the kick panels meet the floor inside and out. And have a good look at the cab mounts on the body side.
11-27-2016, 12:18 PM | #31 |
In my area those pics wouldn't keep me from buying a truck. If the rest of it looks good it may be one to consider.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
11-30-2016, 08:17 PM | #32 |
Thanks for all the help guy! I got a truck last night! It's actually the blue on I first posted about.. he sent better pics and drove it to Vegas. Has a little rust(the least I've seen so far in person) and it drives like like ****. Way too much play in the steering, needs carb rebuilt or replaced leaks a bit of oil. BUT I am stoked!! I'll do a build thread soon.. when I actually do some ish to it.
71 with inline 6. 3 on the tree. |
11-30-2016, 10:47 PM | #33 |
That looks pretty good, I like it.
Almost all of them need rockers and cab corners anyway, so I consider that a given.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
12-01-2016, 11:03 AM | #34 |
Love it brother congrats!!
12-01-2016, 06:44 PM | #35 |
Looks good!
12-01-2016, 09:06 PM | #36 |
Looks like a great starting place. I'd get it running and drive it awhile before I started a teardown.
