03-06-2018, 01:31 PM | #26 |
Re: Project "CREWMAX" Just another crewcab build....
Man its been a long time guys............ BUT good news - project is back on the front burner. Body shop is doing their thing and I am starting to gather parts again.
Just picked up a 2005 Ford F250 complete with Dana 60 front, coil springs etc..... PROBLEM - Where we left off above was frame selection - I couldn't make up my mind and was concerned with using a 1/2 ton frame - SOLUTION - I picked up a 72 Chevy C-30 Cab and Chassis NEW PROBLEM - As SSTIM pointed out the frame does not drop back down and is 2'' higher where the bed mounts vs. 1/2-3/4 ton frame. This would result in raising the cab mounts or a bod lift - I AM OPPOSED TO THIS AS I REALLY DONT WANT TO SHOW MORE FRAME THAN NECCESSARY. SOLUTION - Use the c-30 cab and chassis frame I have, shorten in the middle (flat section). THEN - cut 2'' out of the rear top frame section and box that back in with a C -Channel Someone shoot holes in this plan or give me your thoughts. I am open to suggestions. I really just figured all this out this morning and am still pondering other ideas.
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
03-06-2018, 06:27 PM | #27 |
6>8 Plugless........
I think your plan sounds pretty good. I'm wondering, where the frame kicks up and is higher, could you cut the frame and take enough material out to get the 2" drop needed? Then sleeve and plate it? It should ride really nice with the coil springs in front. Weren't all D60s in the fords starting in 05 and up considered Super 60s?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-07-2018, 04:09 PM | #28 |
Not sure on the "Super 60" I do know that the 2005+ Dana 60's are some stout pieces for sure. And a smoother ride is exactly what I was shooting for since this one will be sitting up and riding on some 37''s.
FRAME UPDATE - I might have tracked down a guy fairly local that has two c20 frames. If that is the case I might go that route. Splice the two and not have to worry about cutting the rear end of this one down. Any crewcab projects out there that can give me an exact dimension to cut this thing? I can wait till the cab is done, then bolt it on, rough set the bed and then cut but would love to cut it all before hand. Anyone have a good dimension??
03-07-2018, 04:23 PM | #29 |
Everyone loves pics - Here are some of the body work currently ongoing
03-07-2018, 04:38 PM | #30 |
just raise the box floor itself enough to get your clearance? box sides stay the same. 2" won't make much of a functional or visual difference
03-07-2018, 07:11 PM | #31 |
t300 - that is why I love this page, didn't think of that option. Will have to ponder that a little
03-08-2018, 08:54 AM | #32 |
You are the one building it, you can do what ever you want to get the look you want. I vote rise the floor.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
04-10-2018, 09:50 AM | #33 |
Alright frame problem is solved..... when shortening will remove section out of the step up area to reduce the height by 2'' or so... then will remove remainder of length out of the middle flat section of frame.
Couple pics of the current body work Also looking for a roof skin with cab light humps? Let me know if anyone has one ( I have posted in the classified section fyi) Next up on the agenda 1. finding a good drivers side suburban door 2. find marker light roof skin 3. deciding on seat selection - probably will use the factory 2002 front bucket seats but not sure if the extended cab seat will be big enough or if I need to run a full size rear seat.
04-10-2018, 09:54 AM | #34 |
pics
04-10-2018, 10:25 AM | #35 |
sitting on the 2wd frame, mocking up new cab mount locations
04-10-2018, 04:43 PM | #36 |
Looking really nice!
04-17-2018, 03:10 PM | #37 |
SWB 4x4 Collector
It's coming along! It always stunk working on it before having a frame under it.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-11-2018, 03:09 PM | #38 |
couple updates
Frame has been shortened and rear sectioned/ lowered for bed fitment.....she is a roller. Too bad all the suspension gets replaced. But it is moving along. Also was able to snag a marker light roof panel that will be grafted into place.
05-11-2018, 03:11 PM | #39 |
another
05-11-2018, 06:50 PM | #40 |
That is looking great and coming along really fast!
05-11-2018, 11:03 PM | #41 |
Looking Real Good.
What is the plan for the roof? Will you just graft the cab lights in the suburban (high roof) and keep the high roof or use (most of ) the yellow top and tie it in to the rear cab? I think it will look good either way. |
05-21-2018, 05:02 PM | #42 |
Going to lower the roof to the truck height - might actually just cut at the windshield pillars and graft in from there, might be easier. But either way the roof line is getting lowered.
06-22-2018, 12:21 PM | #43 |
I really want this build to succeed and have detailed information. I'm collecting my parts for the same build.
THANKS for sharing.
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
08-09-2018, 01:14 PM | #44 |
Looking good! Any updates?
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
08-09-2018, 03:58 PM | #45 |
Nice Project, I'll be watching.
02-09-2019, 08:08 AM | #46 |
SWB 4x4 Collector
How's the project coming?
02-09-2019, 12:33 PM | #47 |
Its coming along.....slow but making some progress
52'' Front springs are in - still not sure how much lift I have. Currently there is 24'' from top of spring plate to top of frame rail. Dana 60 is under it - crossover steering is all sitting in the garage waiting for me to mock up. Need to decide on rear spring hangers - currently going to utilize some 63'' 5.5'' lift springs
02-09-2019, 12:33 PM | #48 |
not sure why all my pictures are sideways these days??
02-09-2019, 01:55 PM | #49 |
SWB 4x4 Collector
Looks good, it all takes time. How did it wind up cutting the frame to lower the rear end?
02-09-2019, 04:12 PM | #50 |
Thought I may be able to add some insight for ya. Here was mine when it had the 4” lift skyjacker 52s on the front with 37s and a 2” body lift. Hopefully it gives you enough reference to help
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
