12-21-2016, 05:05 PM | #26 |
Re: Exhaust Question?
All I can say is being a noobie with exhaust. You all are great help! I just ran the truck and looking close these flow masters gotta go. I originally had 2 inch duals and glass packs(loved the sound but they were about to fall off) going out behind the tires. Now headers, 2˝ inch pipe with 40s that dump right in front of the axle. I was going to finish the exhaust going out the back but I guess it's time to find some different mufflers..
12-21-2016, 05:24 PM | #27 |
Dumping before the axle isn't helping, either. Run the pipes out the back to help with the sound also.
12-21-2016, 05:47 PM | #28 |
Unless you are going to drop it in the weeds, then you gotta get creative to do this.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
12-21-2016, 05:59 PM | #29 |
I had the Rams Horn manifolds, dual 2-1/2", and Dynomax Turbo Mufflers. I loved the sound of them. Then the manifolds cracked and I went to the shortie headers and the truck lost all it's noise. The headers were MUCH quieter than the rams horns due to the flow characteristics.
I agree with the others. Change the MUFFLERS, not the manifolds.
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
12-21-2016, 06:03 PM | #30 |
When I did the exhaust I didn't have enough to have it go straight out the back. I was going to finish it but now I am thinking about going back to glass packs as well. Does anyone of you guys have recommendations for Glasspacks that don't have drone?
12-22-2016, 08:20 AM | #31 |
the flow coming out and dumping right on the ground then reverberating on the ground then up and under the cab is going to cause you a lot of noise and drone as well. Run the exhaust out the back, out the side, any way other than shooting at the ground and it will help.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
12-22-2016, 08:39 AM | #32 | |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
12-22-2016, 10:52 AM | #33 |
Please don't put glasspacks on!!
12-22-2016, 01:35 PM | #34 | |
My brothers race car has gone through about 5 different set ups, granted its a high compression big block street car but from the flowmasters dumping into the axle, straight pipes, cut outs, turbo mufflers, all dumping under it somehow to what he has now, small, race type mufflers that exit to the side right before the rear wheels, its no where near as loud or annoying to take out on the street as it was before.
12-22-2016, 01:50 PM | #35 |
I've run flows on a couple of trucks and I'd say just get the pipes run out the back first. That may be all it takes, and should be relatively cheap. If it's still a little noisy, add a couple of small resonators.
My last truck had a 454 with headers, 50 series with an h pipe and it didn't drone at all with the pipes dumping right behind the bumper.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
12-22-2016, 08:37 PM | #36 |
Yeah, this is your problem. I have 40's and exhaust manifolds (not my choice) and it's way too loud for me. The manifolds may.... may shave 5db or so off the volume. I'd change the mufflers before the headers.
12-22-2016, 08:45 PM | #37 |
12-23-2016, 03:08 PM | #38 |
The hideous sound that comes out of them.
In all honesty, it's your truck. Do what you like. You're not building it for my taste. I'm sure you've heard the cliche about opinions. lol We're mainly just trying to help you with the issue of the exhaust being too loud. Muffler choice is still up to you.
12-23-2016, 03:32 PM | #39 | |
12-23-2016, 10:06 PM | #40 |
Glass packs are one of the more restrictive mufflers out there - the only ones that aren't are the perforated core ones made by Thrush.
12-23-2016, 10:27 PM | #41 | |
https://m.summitracing.com/parts/wlk...WUsRoCB2Dw_wcB |
12-24-2016, 12:26 AM | #42 |
laying low
I completely know what you are talking about with the drone. I had a 2000 GMC that someone had put a magnablow on with dual tails out the back. I like it all except while driving it. It had a horrible drone from 1500 to 2000 rpm, right where the rpms ran in each gear. My wife hated to ride in it. I went to a local muff shop and had them replace it with another thinking it was just burned out. not so. the new one was just as bad. I took the young ladd for a ride and showed him how bad it was and it didn't bother him the least. Got to be that age difference thing. I suggested going with glass packs as I have used on so many trucks over the years and he said that would be even louder. I beg to differ. I had them on all my former trucks and had no irritating drone. A while later I had them install a glass pack in front of the mb and that toned it down to not much more than a stock exhaust sound which also toned down the drone. There are some good sounding mufflers out there. If you care to look there are a few threads on exhaust sounds scattered over the years here. Search exhaust sounds, or lets hear your exhaust purr and it should turn up some threads. I like the sound of Brockmans mellow tone muffs. I think he is in Tx. Giving some thought to looking him up for some too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-24-2016, 10:10 AM | #43 | |
