Old 07-10-2017, 02:35 PM   #26
Hart_Rod
Hart_Rod's Avatar
Re: 71 C10 rebuild 2.0
Clean build.
Hart_Rod is offline   Reply With Quote
Old 07-14-2017, 09:57 AM   #27
RyanB
Saved
Originally Posted by 88Stanger View Post
nice build
Thanks. It can be frustrating because I want to move faster, but a friend reminded me to "enjoy the journey."
'71 Cheyenne 402BB, LWB, factory buckets / AC. Being shortened
http://67-72chevytrucks.com/vboard/s...d.php?t=726968
'87 Buick Turbo T - screamin six banger
'69 Buick GS400 (w/455)
'17 F150
'16 Expedition
RyanB is offline   Reply With Quote
Old 08-12-2017, 05:25 AM   #28
RyanB
Saved
Oh no - they're multiplying!
I hadn't located a transmission to mock up my mounts and driveline. My buddy MShip let me borrow his newly acquired 6.0/4L60e. Hope to get some time this weekend to set it in.
'17 F150
'16 Expedition
Old 08-12-2017, 12:21 PM   #29
RedRider
RedRider's Avatar
Awesome project, it seems every time you linger on it though, something better comes around. Keep up the good work, I'm excited to see this thing come together.
RedRider is offline   Reply With Quote
Old 08-12-2017, 12:49 PM   #30
RyanB
Saved
I bet I am the ONLY one who reads through other builds and says "hey, I think I'll undo half of every thing I've done 'cause that looks ____ (cooler, faster, lighter, stronger...)"
'17 F150
'16 Expedition
Old 08-19-2017, 02:09 PM   #31
RyanB
Saved
Today I set the mockup 6.0/4L60e into the frame using the original big block towers and Dirty Dingo sliders. I haven't built or bought a tranny x-member yet, so it's sitting on the original. It doesn't feel right - I put 2" block under the back of the tranny and it still seems to be too much of an angle. Even with that block the back end is angled 4.5 deg
Thought the motor was sitting a little high, but maybe not that much.
I guess I'll go sit on the mower and think for awhile.
'17 F150
'16 Expedition
Old 08-19-2017, 02:56 PM   #32
Jason7121
Jason7121's Avatar
Mine is set up at 5 degrees down I think they do it like that so the Drive Line clears the center crossmember.
Jason7121 is offline   Reply With Quote
Old 09-13-2017, 12:24 AM   #33
RyanB
Saved
I ordered the ECE mounts for two reasons. I would like to leave the AC where it's at (low) and it looks like they may sit a little lower. Looking at the pics on their site I was pretty convinced the towers that were on the frame I bought were from ECE. But the ones I got are different. It doesn't bother me, here are the two side by side:
Here are the complete ECE setups.
Set the motor in, won't quite clear both the alternator and the AC. Probably trim the frame a bit.
'17 F150
'16 Expedition
Old 09-13-2017, 12:27 AM   #34
RyanB
Saved
Also got some Doug Thorley headers this week. They are very nice and fit awesome.
'17 F150
'16 Expedition
Old 04-25-2018, 12:44 PM   #35
RyanB
Saved
Well, I haven’t posted in a while, but the project has been progressing. I decided to go for disc brakes on the back.
I started with these, but don’t like the e-brakes. So......
I like these a lot better.
'17 F150
'16 Expedition
Old 04-25-2018, 03:57 PM   #36
RyanB
Saved
I wanted to get the shock mounts as wide as possible, so had to cut a slight notch for the brake mount.
'17 F150
'16 Expedition
Old 04-25-2018, 06:23 PM   #37
cornerstone
cornerstone's Avatar
Thanks for the pics! I was planning on doing the same conversion and buying a set of calipers in the top 2 pics this weekend. You say you don't like the E brake setup on them, why is that, if you don't mind?
cornerstone is offline   Reply With Quote
Old 04-25-2018, 06:36 PM   #38
RyanB
Saved
I didn’t want to run cables and really didn’t like the spring setup on them.
'17 F150
'16 Expedition
Old 04-26-2018, 08:58 AM   #39
RyanB
Saved
After I got everything welded up, took it all apart and had it blasted. Then gave it n acid etch, two coats of MasterCoat Permanent Rust Sealer, then two coats of AG 111.
'17 F150
'16 Expedition
Old 04-26-2018, 09:57 AM   #40
RyanB
Saved
I decided to go with the MasterCoat over powder coating due to concerns about future mods or changes. Quick Tip - they sell a Special Chassis kit that includes quart each of primer and AG111 and solvent. They suggest 2 coats of each. One quart was just about enough for one coat on the frame and front cross member. Also, they sell a satin and a gloss black. The satin was more glossy than I expected.
'17 F150
'16 Expedition
Old 04-26-2018, 10:04 AM   #41
RedRider
RedRider's Avatar
Looks great, that AG111 turned out nice! Makes me wonder how flat the gloss black would've been.
1970 C-10 "Old Yeller"
Old 04-26-2018, 10:31 AM   #42
cornerstone
Looks really nice! Back to the rear e brake thing... if you don’t want to run the cable how will you have an e brake?
Old 04-26-2018, 11:09 AM   #43
RyanB
Saved
I am going with a 4l80e, can’t remember the last time I used an e-brake, even on my manual tran cars.
'17 F150
'16 Expedition
Old 04-26-2018, 10:35 PM   #44
RyanB
Saved
Last week I started putting new bearings, rotors and seals on the front.
But I discovered a problem (the hard way). The lowering spindles I got with the other frame I bought are for 1” thick rotors. Looking at everything else I had on hand, I decide to buy a package from CPP with new spindles, rotors, calipers bearings and seals. Should be here next week...look for a new freshly painted set of spindles for sale.
'17 F150
'16 Expedition
Old 04-27-2018, 02:31 PM   #45
RyanB
Saved
I gutted the rear end (open) and put in a new Eaton posi, 3.73 gears,and Moser axles. Can’t find the pics of that process, but here it is in place.
'17 F150
'16 Expedition
Old 04-30-2018, 08:39 AM   #46
RyanB
Saved
Bolted the wheels and a few more things on. Discovered a potential problem.
Looks like the panhard bar might rub against the load bolts in the TA cover
'17 F150
'16 Expedition
Old 04-30-2018, 08:45 AM   #47
RyanB
Saved
But I have to move the panhard bar anyway, because I got to far to the passenger side and it’s going to hit the frame. One of those things that make you say “ah shucks, golly gee whiz” and other things.
'17 F150
'16 Expedition
Old 04-30-2018, 10:07 AM   #48
RedRider
RedRider's Avatar
That kinda stuff is why you keep a bottle of Jim Beam in your tool chest.
402, c10, leaf springs, lowering
