Old 02-13-2017, 10:22 AM   #26
Yaboyolin
Yaboyolin's Avatar
Re: 350 Turns Over Hard and Squeaks
Originally Posted by 67 chevelle View Post
Hows the oil pressure when running ?
Oil pressure gauge is aftermarket and not really working, something I'll try and fix. What should it be?
If someone from the future doesn't come back in time to stop you, it can't be that bad of an idea
Yaboyolin is offline   Reply With Quote
Old 02-13-2017, 10:26 AM   #27
coreyjhen
With a SBC, anything above about 20 psi at idle is OK. Figure around 45-50 at cruise, and 60 at max RPM (for a stock oil pump - high pressure pumps will vary).
coreyjhen is offline   Reply With Quote
Old 02-13-2017, 01:54 PM   #28
cdowns
cdowns's Avatar
me i'd try squirting a big load of marvel mystery in the cylinders for a few days to help clean up the cylinder walls and loosen up the rings// squirt then turn over and repeat timely but effective
