03-03-2017, 02:31 AM | #26 |
Re: 350 crate engine intake and carb possible for $3,000?
Will the factory exhaust manifolds work with the vortec. And does it have drilled dipstick holes on both sides? ?
03-03-2017, 04:01 AM | #27 | |
.. 1st yes. I'd port match the exhaust manifold to the vortec head ports.. 2nd.. I'm almost sure it's on the side all late 70's up are.. I'll look at my engine it's on the stand.. tomorrow.. |
03-03-2017, 09:30 AM | #28 |
vortec motors had on passenger side only.
03-05-2017, 06:13 PM | #29 |
My daughter upped my spending limit to $4000, with that I'll need to include a dual exhaust. I did my exhaust for around $300. If I do a similar exhaust that will leave me $3700 but I'll need to get everything with it, intake, carb, waterpump, etc. any suggestions? She wants it to be strong and sound mean.
http://smg.photobucket.com/albums/v655/aaronhero/ |
03-05-2017, 07:18 PM | #30 | |
03-05-2017, 07:22 PM | #31 |
I looked one up and from what I read to use in in a non computer controlled truck I would need to replace the cam. Unless I'm reading it wrong?
https://m.summitracing.com/parts/nal-12530283
03-05-2017, 07:23 PM | #32 |
Maybe I'm looking at the wrong engine?
03-05-2017, 07:45 PM | #33 |
You don't need to replace the cam. I'm replacing mine because the block I have happens to be drilled for a mechanical fuel pump, but most of them aren't. That just means you need to run an electric fuel pump (and probably a pressure regulator).
The stock cam will make plenty of torque and horsepower with a carburetor (I like Quadrajets) and HEI ingition. I'm running rams horns (2 1/2 inch Dorman) exhaust manifolds on mine because I got tired of messing with the headers. |
03-05-2017, 09:46 PM | #34 | |
Romans 10:9 - The Truth |
03-06-2017, 07:35 AM | #35 |
No need to change the cam.. no need to change anything!!!!!!!!!!!!!!!!!
bolt on a carb intake. plumb in an electric fuel pump put a melonized gear on your distributor.. and a water pump, and your brackets and p/steer pump , alt, and start it.. |
03-06-2017, 01:13 PM | #36 |
Do you know if the block has the clutch lever mount for a four speed? Been trying to get through to summits tech support all morning but it's been busy. Also wondering if I'll have any issues with the flywheel and if it takes a different starter than a regular 350? Will the ram horn exhaust manifolds from the 307 fit? Thanks!
http://smg.photobucket.com/albums/v655/aaronhero/ Last edited by AirSpeed; 03-06-2017 at 01:34 PM. |
05-02-2017, 07:38 PM | #37 |
[IMG][/IMG][IMG][IMG][/IMG][/IMG]Got the new engine installed in the 69 C10 I gave my daughter. She ended up buying a 260 hp 350 from Pace Performance, it came with an Edelbrock intake, Holly Carb, distributor, plugs and wires all installed. Even came with the oil and break in oil in the pan. They even primed it. Also came with a mini starter and flex plate. We put on a dual exhaust and a pair of flowmaster 40's. She spent two days scrubbing 48 years of goo out of the engine bay then used a Scotchbrite pad to rough up the surfaces. I painted the engine bay then dropped the engine in. We picked up the wrong fan, ended up being a reverse rotation so disregard the fan in the pics! That sucker runs great! Tons of power and it does great burnouts! She's getting new tires and rims do once we got the engine broke in we burned off some tread! We also picked up a power disc brake kit to replace the manual drum brakes up front. Haven't got that installed yet. I put in some three point belts since it came without want my grandkids safe when they cruise with their mom! Once we finish all the mechanicals I'm going to repaint the body. It's been a fun project. Even made her a sign to hang in her garage so it's an official service center! I'll post some video of her first drive once it finishes uploading to Photobucket. It sounds really good!
05-02-2017, 07:49 PM | #38 |
Don't look at the exhaust tips! We cut those later and put on some stainless tips.
05-02-2017, 08:06 PM | #39 |
JEGS has a new crate gm motor free shipping $1500.00
http://www.jegs.com/i/Chevrolet-Perf...67353/10002/-1 Check it out. |
05-02-2017, 08:13 PM | #40 | |
05-02-2017, 09:33 PM | #41 |
05-02-2017, 09:49 PM | #42 |
Yea! I gave her the truck, that was as far as my generosity goes! And thanks!
05-02-2017, 10:49 PM | #43 |
Looks great and I am seriously considering that same engine. Can you share the link where you got it for $2400? Thanks!
05-02-2017, 11:13 PM | #44 |
Just checked with my daughter, I was way off, she actually paid $2900 at Pace Performance
06-13-2017, 08:57 AM | #45 |
video of my daughters first drive with new engine
Can't seem to get it to show up!
http://smg.photobucket.com/albums/v655/aaronhero/ Last edited by AirSpeed; 06-13-2017 at 09:06 AM. Reason: Video |
06-13-2017, 09:40 AM | #46 |
Good info
72 White Cheyenne, The Ghost |
