11-25-2020, 11:50 PM | #26 |
Old member
Re: Push Brake Pedal and right turn signal comes on???
Glad you figured it out.
11-26-2020, 11:26 AM | #27 |
Thanks Andy
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-24-2024, 01:06 PM | #28 |
This is an old thread, but just wanted to pass on some information with this very problem. I swapped out steering columns as stated above my right turn signal would come on with the brake pedal being pushed. What I found was that my turn signal switch was tightened down very tight to the point that the plastic turn signal was slightly warped. I didn’t notice until I started troubleshooting this issue. Long story short, I had to back out each bolt until I found the one that was tightened too far down causing the grounding issue. This solved my problem.
Thank you all for this site, it is a life saver!
