Old 04-11-2017, 02:40 PM   #26
randy500
Re: Lifting cab and cab mount torque?
For torque just tighten them up, you should feel when the spacer bottoms out, then 40 pounds or so on the rear and a little more on the front if you want.
Save your old spacer tubes and make sure the new ones you buy are the same length, if they aren't then cut or make new ones the correct length. I bought mine from GMC pauls and some of the spacers were not the right length, don't remember which ones though.
Don't use the poly urethane mounts they suck and a lot of the rubber ones are not correct too. The best replacements look just like factory, for the 1/2 tons anyway, don't have experience with 3/4 tons
randy500 is offline   Reply With Quote
Old 04-12-2017, 08:24 AM   #27
Shaky
Six in a row makes it go...
Shaky's Avatar
I picked my empty cab up by the door frame with no problems. Had to put a little ballast in the back to balance out the firewall.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
