Old 05-19-2017, 03:10 PM   #26
NeoJuice
Re: 49/51 3100, 4bt Turbo, ZF-5, Classic
Originally Posted by andreas_kc View Post
Trying to figure out parking brake cables. I think I'm going to weld a brake clip to one of the running board supports to run the cable to and use that to connect to the old parking brake bar.
I'm very interested in your parking brake setup. I will be doing the same thing to my truck soon. I have a simular rear disc setup with the cable guide lever & spring on the caliper. I want to hook it up to the stock cross shaft and I'm interested in what parking brake cables your using as well.
NeoJuice is offline   Reply With Quote
Old 05-19-2017, 11:14 PM   #27
joedoh
joedoh's Avatar
well looky there! cant wait to see this in the frame
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 05-19-2017, 11:30 PM   #28
mongocanfly
Post Whore
mongocanfly's Avatar
those 4bt engines are nice units..very poplar for swaps..around here the jeep guys snatch em up quick...there's a bunch of jeeps using em..
what brand gas tank are you using?...that's a nice one
Old 05-20-2017, 08:14 PM   #29
andreas_kc
Got the zf-5 hooked up today. Resurfaced the flywheel, spent all morning looking for the right pilot bearing to go from the zf-5 to the Cummins flywheel. New clutch and slave cylinder.
'51 Chevy 3100 Short-bed
2000 Custom Ducati Monster 900ie
andreas_kc is offline   Reply With Quote
Old 05-20-2017, 08:17 PM   #30
andreas_kc
Ordered it from Brothers thou I think Performance online is the mfg.
Old 05-20-2017, 08:20 PM   #31
andreas_kc
Me too! Hopefully tue/wed... thou I have a lot to do before tue. Found out today that one of my mid engine mounts runs into some Turbo oiling tube that will need rerouting.
Old 05-20-2017, 08:25 PM   #32
andreas_kc
I stopped thinking about this and ending up calling Controlcables. For $60 I am getting a completely custom set of cables that go from the brake calipers to the intermediate parking bar with all the appropriate ends. Will certainly update when I get them and also when installed.
Old 05-26-2017, 08:27 PM   #33
andreas_kc
My controlcables order came in the mail for the parking brake. Custom made to match the parking bar clevis with a push-in fitting that matches my disk brake rears. Looks perfect on initial fitting.
Old 05-26-2017, 08:31 PM   #34
andreas_kc
Engine and frame made it to the shop. Need a little fabrication and engine hoist help. Even this hoist has a difficult time lifting this engine without coming off the back wheels.
Old 05-26-2017, 10:02 PM   #35
andreas_kc
First problem is the turbo drain is sitting right under the middle engine mounts I want to use. They make a AN -10 fitting that replaces this. The metal tube just needed to be pounded out from underneath. Second pic is with mounts + starter removed + tube removed.
Old 05-26-2017, 10:08 PM   #36
andreas_kc
Had to drop the oil pan and reverse it. The bread truck had the sump in the front which puts it in a bad spot for the mustang ii crossmember. Thankfully Cummins carries a pickup for the rear and the pan is reversible. This also required moving the dipstick and small plug for the old location
Old 05-26-2017, 10:10 PM   #37
andreas_kc
Still stuck on a solution for the turbo drain plug, as the AN fitting is still pretty difficult to run a hose around the mount. Thinking next week will cut a hole in the mount to run it up
Old 05-27-2017, 12:32 AM   #38
mongocanfly
Post Whore
Pretty smart on their part to make the oil pan reversible...
Old 07-03-2017, 06:39 PM   #39
andreas_kc
Been traveling for work the last month and finally got a day(today) right before the 4th of July to wrench.
Got the turbo drain line sorted out, it required cutting up the mount and some an fittings/hose.
Old 07-03-2017, 06:50 PM   #40
andreas_kc
Cut out some more box plates to go back to where transmission crossmember starts.
Also, marking up the frame to figure out where everything goes.
Cut and roughed in the transmission crossmember. It is a Jimenez Bro's Custom crossmember. Adjustable up down forward back.
Will be welding box plates this week and will need to figure out fabrication of mounts that go on the frame.
From today's measurements it looks like the engine may fit without firewall modification with rear cylinder in the firewall recess some. Don't know about transmission clearance thou. The zf-5 is huge.
Old 07-17-2017, 09:20 PM   #41
andreas_kc
Big picture of where engine is currently sitting....
Old 07-17-2017, 09:21 PM   #42
andreas_kc
Frame boxed up now from front to transmission member.
Somehow got pic of frame with errant fish toy...
Old 07-17-2017, 09:21 PM   #43
andreas_kc
Passenger side frame pic (sun pretty bright late in the day)
Old 07-17-2017, 09:23 PM   #44
andreas_kc
Current altitude.... oil pan is currently slightly lower than front crossmember...
Distance from electric fan to front pulley... hard to see in this pic but the center of the fan is offset from the front pulley, so there is slightly more room here than you really see from this angle. May want to put a fluidampr or balancer of sorts on the crank pulley in the future.
Old 07-17-2017, 09:25 PM   #45
andreas_kc
Engine mount clearances....
Passenger side/starter
Driver side...
Old 07-17-2017, 09:25 PM   #46
andreas_kc
Lower side of mounts look like they are more going to fit nearly on top of frame... and almost need the engine to gain a little more altitude for access to the lower nut on the mount... even then may need to cut the stud slightly to fit.
Engine is about on a 4 degree slope. Rear is pretty adjustable if need a little more/less angle
Another view from front of engine mounts...
Old 07-17-2017, 09:26 PM   #47
andreas_kc
Some shop photos...
A few interesting cars in this week... Nice black Thunderbird, red stang, 50s(?) Continental.
Hope to bring this back to my garage in the next week or so, slow going working in someone else's garage but definitely needed the extra hoisting help.
Old 07-30-2017, 11:32 AM   #48
andreas_kc
Engine is mounted in, have a bunch of pics that will take a few days to put together... here is the final result.... close up of passenger/driver side...
Old 07-30-2017, 11:32 AM   #49
andreas_kc
Additional pics...
Old 07-30-2017, 11:33 AM   #50
andreas_kc
Moar pics
4bt, 9-inch, cummins swap, turbo, zf-5
