Old 08-23-2020, 11:10 AM   #26
Axle
Axle's Avatar
Re: Wheel Vintiques fitment
Originally Posted by SCOTI View Post
Van Ralleys are 6.5".
Thanks for catching that. corrected.
Alex.
Axle is offline   Reply With Quote
Old 08-27-2020, 08:46 PM   #27
Robzkombi
Quick update, went ahead and cancelled the order with wheel vintiques. Found some OG wheels, with caps and trim ring for a smoking deal and went with those. Did a trial fit with the Bell-Tech spindles and coils and happy to report no issues whatsoever. Then again these are original 15x6 wheels and not the 15x7's Vintiques I was originally going with...sooo um yeah I'm a happy camper.
Robzkombi is offline   Reply With Quote
Old 08-28-2020, 09:15 AM   #28
SCOTI
SCOTI's Avatar
OE 6's are usually good to go unless there's a unicorn-combo of parts. I just test fit a combo that had me nervous (CPP modular 2.5" spindles & a heim-joint TRE set-up) but no clearance issues so far.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-28-2020, 02:23 PM   #29
Robzkombi
clearance is tight, less than a 1/4" but no scraping or rubbing issues. I'm happy I went with the OG set.
Old 08-28-2020, 03:44 PM   #30
SCOTI
SCOTI's Avatar
About what I had on mine. I set out for a stock big & little look so my rears are OE steelie too just bigger/wider. It's a classic, timeless look that's always in style
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-28-2020, 05:06 PM   #31
Robzkombi
Im going with the 235/75/15 thin white wall all the way around this time. 20" were/are cool but im over that now. This being my first Chevy budget project,( I was a VW fan still am,'62 double cab, 65 sunroof Kombi and my last one a 58 Kombi hence the name robzkombi). I'll just lower it a bit do body and paint, interior and any needed electrical repairs. Keep it simple and enjoyable with a few period correct accessories here and there. So Far so good!
Old 08-28-2020, 05:17 PM   #32
SCOTI
SCOTI's Avatar
Solid sounding plan to me. I'll watch for posts/details.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-18-2020, 10:15 AM   #33
Robzkombi
Okay so after getting the 235/75/15 wheels mounted to the OG 15 inch wheels and installed on my truck I did have a small issue with grinding. i purchased a 1/4" spacer and although it did minimize the grinding, there was still a slight rub. Turns out it was the clip on wheel balancing weights that were the issue. Went back to Discount Tire and had them re-balance the wheels this time using the stick on weights and that took care of the issue, i'm now a happy camper/trucker.
Old 09-18-2020, 11:09 AM   #34
skyphix
I had the same issue with Rallyes and wheel weights. They did self clearance on my 1600 mile drive, but I also did run a spacer. I was already using stick on wheel weights unfortunately. Glad you got it worked out!
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 09-18-2020, 11:18 AM   #35
SCOTI
SCOTI's Avatar
If you needed/had stick on AND clip on balance weights, something was not right.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
