Old 06-06-2017, 01:04 PM   #26
NewType72
NewType72's Avatar
Re: Dumptruck Dolly
Woah, those 19.5's are a must for any dump truck now that I've seen them, holy cow those are awesome on these little trucks. The door logo is pretty awesome, looking forward to this build, subbed
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 06-07-2017, 02:58 PM   #27
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
bigrigpardo's 19.5" wheels look great...I need to find 2 more 17.5 inch tires for the front yet...and I am looking forward to getting the dump bed set, hopefully soon.
fishnixon is offline   Reply With Quote
Old 06-07-2017, 03:03 PM   #28
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by bigrigpardo View Post
its a 305e v6 and a 4 speed. eaton rear with crazy gears. 45-50 is tops on highway.
I have never looked at the V6 up close...Cool. I have a Eaton HO72? with crazy gears as well, but its in the back yard under a tarp. I did seem to get the last set of brand new drums off of a shelf in Seattle...probably 15 years ago. Those are hard to come by.
Old 06-07-2017, 05:06 PM   #29
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by 68Gold/white View Post
Way cool.
Old 06-09-2017, 09:38 PM   #30
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Found my silver bumper, 3 dents and a couple of edges bent...no problem.
Old 06-09-2017, 09:41 PM   #31
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Another view
Old 06-09-2017, 09:44 PM   #32
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
An unsightly carriage bolt opening that needs repair.
Old 06-09-2017, 09:47 PM   #33
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Using the scrap bumper for the filler.
Old 06-09-2017, 09:50 PM   #34
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
welded up, and used flap disc to smooth it out.
Old 06-09-2017, 09:53 PM   #35
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Pounded out the dents, straightened the edges and put a skim coat of filler prior to primer.
Old 06-09-2017, 09:54 PM   #36
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Primered and done for tonight.
Old 06-11-2017, 01:37 PM   #37
NewType72
NewType72's Avatar
Re: Dumptruck Dolly
Great work on the repairs.
- Dylan
(209)-985-7721
Old 06-12-2017, 12:53 AM   #38
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thank you...onto paint and putting it back on.
After getting it back in place, my son says that the other white trim pieces look out of place...I'll take care of that tomorrow.
Old 06-12-2017, 11:05 AM   #39
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I am pretty happy that Dolly got a facelift of sorts.
Old 06-17-2017, 06:58 PM   #40
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Busted and rusted side mirrors have to go.
Old 06-17-2017, 07:06 PM   #41
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Found nice replacements at Champion for about $9 each. Dolly is not much for a lot of shiny parts, so I scuffed up the chrome, and shot some white on them, like the originals were.
Old 06-17-2017, 07:17 PM   #42
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I am going to put "dirt" tires on the rear wheels, as this is 2 wheel drive...the street tires may struggle up and down my hills...I found wheels and cleaned them up. I'll have to wait for good weather to get the epoxy primer on them.
Old 06-17-2017, 09:01 PM   #43
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Here are the tires going on the back. I'll run the street tires in front.
Old 06-30-2017, 04:37 PM   #44
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Wow! The weather has just been terrible! Rain for days on end. Finally found a day to get the painting accomplished on the wheels. Monday, I get the new tires mounted.
Old 06-30-2017, 04:42 PM   #45
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Check out this rusty crossmember holding up the carrier bearing. That will have to be taken care of next. Notice the lack of exhaust pipe. A new exhaust is on the way, and should arrive about July 19th.
Old 06-30-2017, 05:10 PM   #46
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Only crossmember that I have is from a half ton truck. Notice the width dimension of approximately 37.25 inches. The 1 ton is approximately 34 inches as the leaf springs are on the outside of the frame. The height is the same, but I will have to come up with some elevation for mounting the carrier bearing. It is what I have, and I will fabricate this to work and hopefully not look hokey.
Old 07-01-2017, 08:03 PM   #47
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Inside width of Dolly's frame is 33.25". I made a "Z" cut in the half ton crossmember similar to chopping a frame to make a shortbox. I figured it would add strength.
Old 07-01-2017, 11:25 PM   #48
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Welded up the crossmember and shot some primer until I get at it again. There are upper brackets I have to come up with if I want it to look stock. Not sure what I'll do.
Old 07-01-2017, 11:34 PM   #49
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I got distracted trying to finish up the dual exhaust on the car hauler. You'll see some exhaust pipe examples on the back of the rolloff that I got from my local parts store. If you look closer, you'll also see MORE projects at different stages...I count 4. Also, more rain! I think I will sandblast the crossmember when it clears...
Old 07-02-2017, 08:01 AM   #50
68panelman
68panelman's Avatar
Re: Dumptruck Dolly
Missed this thread. Super cool truck
68panelman is offline   Reply With Quote
