06-25-2017, 02:28 PM | #26 |
Moderator
Re: Looking For A Radiator
I've been using a champion aluminum radiator in my 72 for over a year now, works great. Just picked up a second one for my 68 as it sprung a leak the other day. Fixing a 40+ year old radiator is a game, it's only a matter of time before it leaks again.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
06-25-2017, 06:12 PM | #27 | |
Post Whore
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-25-2017, 06:14 PM | #28 |
Well I removed both lower radiator retainer brackets and for the moment have 4-row replacements from GMC Paul's in there. I can remove those if I want and go back with my newly painted originals or some NOS 4 row's that I have coming. I have decided to go with my KKS all aluminum radiator for now.
My future plans are to get my original radiator recored and maybe put that in there if need be. The ability to remove and replace the lower radiator support brackets is a game changer of sorts. I think I will try and buy an OEM 4 row radiator or two for saving....getting those recored when I can to have for the future. Last edited by In The Ten Ring; 06-25-2017 at 06:24 PM. |
06-26-2017, 01:43 AM | #29 |
Kyle Seal
, go to post #365 on my build thread. http://67-72chevytrucks.com/vboard/s...603726&page=15 My radiator and cooling works great and I just tested it in 110 degree heat for over 100 miles with great results. Water temp was rock solid at 202 degrees at 75mph. Also, the system now has 11k miles on it. I'm using Engineering Cooling Products radiator and they are around $219 and are direct drop-ins. Good stuff! https://www.speedcooling.com/1967_19..._Radiator.html
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
06-26-2017, 11:52 AM | #30 |
I love this thread. I'll be at that point soon.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
06-26-2017, 12:38 PM | #31 | |
06-28-2017, 10:22 AM | #32 |
I ended up replacing my old radiator instead of repairing it. I went with a stock replacement and got it from Wes up at Classic Heartbeat for $370. Quick install and is working great. I still have the stock one, not sure what I will do with it.
09-22-2017, 01:16 PM | #33 | |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Can you comment on how your ECP radiator has held up through he summer?Is it still doing a good job as you reported in June? When you say " is a direct drop in" as you were dropping in where a 4 row originally was or did you have an original 2 row?? I found them and like the fact that its full 1" cooling tubes, fully welded and mimics the looks of the original with the stamped tanks....would probably disguise well with a shot of black paint. Looking to swap in where a 2 row was. thanks! |
09-25-2017, 09:51 PM | #34 |
ttt
09-26-2017, 07:41 PM | #35 | |
09-26-2017, 09:43 PM | #36 | |
09-28-2017, 05:45 PM | #37 |
I had to cowboy up and order one for my big block super. Seems to be a good bargain since I cannot have mine rebuilt for this much.
09-28-2017, 09:10 PM | #38 |
I am a Referee of life.
I originally had a 2 row. I used a set of brackets from a vendor on here and put in a 4 row from O'Riellys. It cost right at $200 5-6 years ago. Direct fit and it looked high until I pushed the rad down into the rubber mounts good.
It's probably overkill for a 250 but I would rather have more than I need rather than less, just wish I could make money work that way.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Tags |
brass, copper, radiator |
