08-03-2017, 03:53 PM | #26 |
Re: CPP Disc Conversion - Good and Bad
Thanks for the write up. Are you running the 12" rotors from CPP? I am getting ready to order, but don't want to switch wheels.
I have about 14.5" across. Do you know the inner diameter on your new rims? |
08-05-2017, 11:40 AM | #27 | |
08-11-2017, 11:26 PM | #28 |
What size bore of clutch MC is needed for the original hydraulic clutch?
Looking at this setup: https://www.performanceonline.com/WI...YLINDER-19753/ |
08-12-2017, 12:45 AM | #29 | |
60-66 Nut
You need a 1" bore clutch master. That is what I supply in my kit for those with the '60-'62's that are keeping the original clutch slave cylinder.
http://www.67-72chevytrucks.com/vboa...d.php?t=362375 Quote:
08-13-2017, 11:57 AM | #30 | |
Your brackets seem to be really popular in this forum and others. Using your kit to complete the power brake conversion on my 61, I'd need a booster, brake MC, and some split brake lines, right?
08-13-2017, 11:15 PM | #31 |
60-66 Nut
That and if you are changing to front discs, you will need a disc/drum proportioning valve also.
08-13-2017, 11:49 PM | #32 |
You can have it here or put it on your frame. the proportioning valve.
08-14-2017, 12:02 AM | #33 | |
http://www.67-72chevytrucks.com/vboa...d.php?t=362375 |
08-29-2017, 04:19 PM | #34 |
I am about to tackle this on my '60, please post some photos when your done so I can learn from your hard work
08-21-2018, 12:09 AM | #35 |
After a long hiatus, I finally started back on the truck. I found my pressure problem was a heavily clogged master cylinder. No amount of compressed air or cleaning would unclog it. So, I bought a new Dorman unit for roughly $50 from summit and after bench-bleeding, I was back in business.
I was able to shift and brake better than ever. Now, the real fun begins. Looking for a new motor and tranny. |
Tags |
#brakes |
