08-20-2017, 07:28 AM | #26 | |
Re: Nobody has restored or repaired a steering wheel yet
A good job requires thoroughly cleaning contaminants/dust and a good epoxy. You can also drill little holes in the v-cut to help epoxy grab. I only used bondo for minor filling. I first used JB because it's runny to get it "into" the material. Then I used a pasty epoxy like PC7 to fill.
08-20-2017, 11:12 AM | #27 |
Old member
The first coat of blue is on and drying in the sun. Suppose to be 90's here today. I'll wet sand it some tomorrow if needed before I spray the clear. Two tone white & blue as it came from the factory.
It's not perfect but it beats what it did look like. I redid the Chevelle wheel back in 2012 and it looks as good today as back then.
08-20-2017, 11:13 AM | #28 |
Junior Member
Keep the pictures coming
08-20-2017, 12:35 PM | #29 |
08-20-2017, 01:35 PM | #30 |
Here's my 61 Impala wheel
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
08-20-2017, 02:05 PM | #31 |
Here are some pics of my steering wheel. Like I said it seems to be holding up very well. As mentioned in an earlier post I used PC-7 two part epoxy to fill all of the cracks. Also this was not my original wheel, it was too far gone in my opinion. I bought this three spoke version at a wrecking yard.
08-20-2017, 04:37 PM | #32 |
Old member
The 67 SS Chevelle wheel I used bondo the cracks where not that bad. The wood and the 64 Impala wheel I used what is in the picture. You have to cut off just enough to work with because it will harden up pretty fast on you. Keeping it wet helps though. That's why I didn't worry aboy excess I just ground it off after it dries good.
Tags |
restore, steering wheel |
