09-10-2018, 07:56 AM | #26 | |
Re: K20 brake part question
09-10-2018, 12:57 PM | #27 |
Please post up what you guy's have found. Pictures is possible. Not much info of real life rebuilds on these old axles and brakes.
1961 chevy K10 my build is------------61K10 build |
09-10-2018, 08:36 PM | #28 |
So far NAPA here in town has had everything I’ve needed. Wheel cylinders, shoes, hardware kit and grease seals all on the shelf. They do not have drums but I don’t need any yet. I don’t know how much this helps but here’s the part number of my front drum:
09-11-2018, 02:18 AM | #29 | |
As for the drums, hope yours are still good. They have been out of production by all suppliers for many years. Finally found a set of old stock through a place in Southern Cal called Drum Garden. Guy named Craig runs it and is the one to see for stuff that doesn't exist. Not cheap but after a year of looking was not in a position to complain. So while I was looking for the correct drums I came up with a plan B to get my truck rolling. There is a 70's era Ford drum that is the right dimensions except for a few 10ths too large in diameter, so the shoe contact is high in the middle. Well I drove it around a little while I got the rest of the truck dialed in, and pretty soon those shoes wore in just perfect, and now after about 3000 miles it stops great. If I had known how well they were going to work I would have had the shoes arched to fit the larger drums and been done with it. Still haven't installed the correct drums. Hope this helps, Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
09-11-2018, 08:43 AM | #30 |
They list a hardware kit whether or not its correct is yet to be determined. I'm picking it all up this afternoon. All I really need out of it is the pins but I will compare the rest to see what matches.
Good info about the Ford drums. I thought these axles were pretty much the same no matter what brand they came in, so I would think someone would still be making a drum for them. |
09-11-2018, 08:56 AM | #31 |
One more thought: did you try the back drums on the front? According to the factory manual the fronts should be 1/8” larger. Rear is listed as 12” front 12.13”. Not sure if that would matter.
09-11-2018, 11:50 AM | #32 | |
On your brake lines, sounds like HD is different, as my standard 3/4 was the same as 1/2 ton. If you can't make that short line yourself you can send to Classic Tube and they will make a new one for you. For the Ford drums, the part number on my receipt is 60131-2028 (2018) Not sure what Brand that number is for, but got those drums at Drum Garden as well. Do you know about Torque King? They are a great source of parts and info on that front end. (but unfortunately no brake parts). Hope this helps, Tom
09-11-2018, 08:21 PM | #33 |
I'm familiar with Torque King, have them bookmarked mainly for the T221 parts they carry.
Does your rubber brake hose go directly to the wheel cylinder then? If so does it have a 90* fitting at the wheel end? There is not enough clearance on mine between the knuckle and wheel cylinder fitting to get a regular hose on there. The hardware kit I picked up seemed pretty generic, the hold down springs and cups weren't exactly the same but seem like they work. Found I've got a broken bottom shoe spring, so now to try to find one of those. Any idea what exactly it's called? It's the one by the adjuster that keeps the bottom of the shoes together. Last edited by jdl71; 09-11-2018 at 08:45 PM. |
09-12-2018, 01:48 PM | #34 | |
Looks like you are having same problem with springs as I had. Wound up having to dig through bins at a brake supply house and a local shop that does a lot of work on the kind of old/odd junk that seems to always follow me home. Never found any parts sources with complete/accurate listings on the hardware and springs for 3/4 ton, so is a match by eye scavenger hunt. I needed the same spring as I recall, and everybody tried to sell me the 1/2 ton version, which was too short
09-17-2018, 01:00 AM | #36 |
Good to know, ones I found I recall all too short, thanks for sharing info
