Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-21-2018, 10:26 AM   #26
1965c50
Re: 1965 c50 drag car hauler help
No problem. Shoot me a message with your number. I can text updates faster than this board. I rarely come in here. Not enough traffic b
1965c50 is offline   Reply With Quote
Old 01-21-2018, 10:50 PM   #27
Free Candy Inside
PM sent
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 01-25-2018, 05:54 AM   #28
PaulJWood
The L is short for LCF Low Cab Forward.
The Hood on an L is shorter than a C.
To make it easier to notice, you can see the truck: The head of C truck tends to be much smaller than the L
PaulJWood is offline   Reply With Quote
Old 01-26-2018, 06:16 AM   #29
stsalvage
Scrapper 1
stsalvage's Avatar
I had a 1965 3 ton bob tail.my plan until is was destroyed by kids and lite it on fire.It was a blue 20 footer Bob tail it had a 283 with a 4 speed with a spite rear end.I was going to buy a internal rolling chassis from a 1990.Was going to use the I beam power steering and disk brakes and the better 2 speed rear end and better drive shafts plus use the alum Gas takes and the better 16 foot wood bed that was almost brand new guy wanted 3300.00 for the rolling chassis.All i was going to do was add Power brakes from a 1972 chevy truck bracket and booster.But now that hydro boost works so well.that be my next option mine was not a snub nose mine had the long hood
stsalvage is offline   Reply With Quote
Old 02-19-2018, 06:01 PM   #30
1965c50
Some custom motor mounts and we finally have a good mock-up.
Old 02-20-2018, 02:54 PM   #31
1965c50
The donor NV4500 is mated up. Have to move the crossmember back and a few mods for driveline angle and that check is written. Also removed the rear cab mounts to be re-vulcanized. I found a place that has a jig for a c30, should be the same. I’m gonna send it out and find out if it will work.
Old 02-28-2018, 03:04 AM   #32
jarrodblake
jarrodblake's Avatar
Awesome build! What airbags are you running? Dimensions, LBS, make model? I'm getting ready to order a set. I was thinking about 5000lbs bags each in the front for my C30 car hauler under heavy loads my truck bottoms out. Also can we get some more pics of how there mounted. I will definitely be following this build! So far you're doing the same mods as I will be doing. What are you doing for your clutch and flywheel? I have a nv4500 out of a 95 chevy 3500 it came with everything as well, but the new flywheels are balanced different then the one on my 70s engine. Dis the newer clutch bolt on the older flywheel?
jarrodblake is offline   Reply With Quote
Old 02-28-2018, 11:13 AM   #33
1965c50
We ran 6k bags up front and 12k in the rear. We purchased our system through x2 industries. The brackets for the bags were all hand made. The brackets s that came with the kit looked like ****. Here’s the only pics I have on me of the bags
Old 02-28-2018, 11:15 AM   #34
1965c50
Body is back on for final mock-up.
Old 02-28-2018, 11:19 AM   #35
txagincali
Please tell me the super singles are staying and not used for mock up too!
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint)
1969 GMC C10 Pickup SWB Stepside (heart transplant)
1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts)
1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts)
txagincali is offline   Reply With Quote
Old 02-28-2018, 11:21 AM   #36
1965c50
Since no one makes the parts we needed. Everything we’ve made has been computer modeled so it can be made again. So if you want the same parts as we used. We can make em and ship em. May save you some time on the math. We can remake: the frame recesses for the kframe crossmember, 3 pint inner frame motor mounts for SBC/BBC, rear cab mounts (all steel) airbag mounts for kframe crossmember.
Old 02-28-2018, 11:49 AM   #37
Gypsyman
Nice to see heavy hauler build. I have a few here waiting for the same treatment. Has anyone ever found an actual max load rating for the Chevy/GMC A-arm steup that we all seem to go with?
Richard
Gypsyman is offline   Reply With Quote
Old 02-28-2018, 12:27 PM   #38
txagincali
Ooo I might be down for a set of BBC motor mounts! I haven't started pulling anything yet from my 69 C50 or my Topkick Donor but when I get to that point and find I am needing some, I will definitely look you up. ~3 months time if all goes well.
Old 02-28-2018, 05:07 PM   #39
1965c50
Super singles are here to stay.
Old 02-28-2018, 05:08 PM   #40
1965c50
Start a build post so I can follow
Old 03-15-2018, 12:05 AM   #41
jarrodblake
Any updates? Also do you have a link on the bags you used? or part numbers make model?
Old 03-15-2018, 11:48 AM   #42
1965c50
I ordered my whole system through x2 industries. They built the system for me. Ask for Chris. He’s one of the owners. He can tell ya when he set us with. We’re getting ready to take off the body for the last time. Off to body and paint. Fishing up turbo mock-up and 4 link starts next week. Wish I had more pics for ya.
Old 03-15-2018, 12:24 PM   #43
jarrodblake
Thanks, I checked their website it looks like I will have to call them. I can not find the 12k rear bags I see 10k bags.
With that said any more info on this turbo build? Are you still running the big block, if so what carb are you going to run I assume you're going with a blowthrough setup, or are you going with EFI? I have been considering turboing my truck. I turboed my last rat rod I built. I still have an extra hx35 I am trying to decide which vehicle I want to put it in.
Old 03-15-2018, 01:18 PM   #44
1965c50
Yep. Still running the big block. Twin BW 66mm. Fitech 2x4 FI system.
Old 04-02-2018, 10:53 PM   #45
1965c50
Progress is slow but steady. Steering is all bolted in and tires are mounted. Fenders get trimmed Wednesday, so we can lower the front back under its own weight and start the back suspension. Cab is striped and otherwise ready to be sent off for its first round of work.
Old 04-06-2018, 03:35 PM   #46
1965c50
We got a mock up on the headers. Serpentine is in. Now we can start the turbo piping. Slow and steady. More slow though.
Old 04-11-2018, 10:35 PM   #47
1965c50
Fenders are cut, there’re being stretched to contain the tires when it’s dropped. About an 1” of clearance on the inside when fully slammed.
Old 04-11-2018, 10:39 PM   #48
1965c50
The new intake arrived today. The fitech throttle bodies are an 1” shorter than the mockups so we should have room for he hat. Stainless column is also in and waiting on a heim joint to finish up the steering.
Old 04-14-2018, 05:29 PM   #49
luvmytruck
please answer me a question! are you going to use the shift boot in the picture? (post #45)is it the original lcf boot? if not let me know I would buy it if you are going to use it maybe you could send me pictures of it with a ruler next so I can see the dimensions. what I am looking for is an original boot for an lcf, thanks
gary
luvmytruck is offline   Reply With Quote
Old 04-16-2018, 10:07 AM   #50
1965c50
gary
That’s the shift boot from the donor NV4500. It was out of a late 90’schevy 1 ton
