10-31-2017, 03:22 PM | #26 |
Re: SBC 400's cubic incher...any good?
I have a 400sbc in my 72, and it has been in there for the last 16ish years.. no issues and plenty of tq... I love it..
1972 Chevy C10 400sbc 4sp Matthew 4:19 And he saith unto them, Follow me, and I will make you fishers of men. |
10-31-2017, 03:39 PM | #27 |
I found a 400 in the jy with just under 70k on it. Got it for $175.
Stripped it down cleaned it up,put on a few aftermarket parts and plopped it into my k 20 with most of the oe dressings. It was a hard decision too keep the rams horns instead of headers. I'm way happy I found that motor it's certainly not AS torquey as my bbc but I would say it's rite in line if not more torque than my slightly worked 355 but at way different rpms. Without going BBC, it's exactly what a big heavy k20 needed.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
10-31-2017, 03:56 PM | #28 |
laying low
Shoot. I’d leave the 350 in it while i freshen up that 400, swap em out and never look back.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-31-2017, 04:51 PM | #29 |
damn.....you guys are killing me here, lol.
I'm torn to go get that darn thing.... Although 'today'....I have no need for it given the way my truck is currently running which is very nice.....but its going to need renewal within a couple of years I think. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
10-31-2017, 05:02 PM | #30 |
laying low
Well we are your support group bud.
When are ya leaving?
10-31-2017, 06:41 PM | #31 |
motor exploder
Says the guy who has FOUR trucks in his signature!!!! You only 'need' one! Get the 400!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-31-2017, 07:14 PM | #32 |
I would probably do the same.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-31-2017, 08:27 PM | #33 |
Wrong, totally different blocks. The SBC 400 as someone has already said have problems with cooling. If you bore it out it has worse problems with cooling. I would go with a 350 block , you can always machine it and put a 383 crank in it if you want more cubes.
10-31-2017, 09:12 PM | #34 |
Plenty of 400 SBCs have run for decades without cooling problems. You need to have the steam holes in the heads and have a cooling system that works as it's supposed to.
10-31-2017, 09:17 PM | #35 |
BUT, you cannot take out the 350 block to 4.125+. The only cooling problems I've really seen with a stock 400 is lack of maintenance with the cooling system. Dirty and partially plugged radiator immediately comes to mind. I've never had an overheat problem with any of the 400s I've had
10-31-2017, 09:43 PM | #36 | |
Besides this gives you two years to build it. I'd say that makes you a good planner. Yeah, that's it, a good planner.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
10-31-2017, 09:45 PM | #37 |
My vote is the 400...I have run them since 1970....as long as your cooling system is good...no problems...here is an example for you...drive something with a 305....then drive the 350...quite a difference in power and torque....the 400 is that much stronger over the 350. Here is a pic of my 400 bored .030 which is 406....scat crank and 5.7 eagle rods and keith black dished pistons and vortec heads...around 9.1 compression. I will be dropping this in my 66 c10 with a 700r4 and 3.73 gears very soon. Run the 400 you will not be disappointed.
10-31-2017, 10:19 PM | #38 |
Quick question:
What is the externally balanced thing?....is this something to watch for or a problem or? Coley
10-31-2017, 10:25 PM | #39 |
laying low
That's what I'm sayin. Just like that.
That's a sweet combo for your 66.
10-31-2017, 10:34 PM | #40 |
10-31-2017, 11:37 PM | #41 |
All other SBCs have internally balanced crankshafts. The 400 is externally balanced, which means the flywheel or flex plate will have counterweights to balance the rotating assembly. You'll just need to make sure you have a flex plate or flywheel that's for a SBC 400. If you don't you'll have a crazy vibration.
11-01-2017, 06:27 AM | #42 |
A harmonic damper and fly wheel/flex plate is what's needed
If it don't already have these. Also I had to drill and tap the block on my 400 for the clutch ball stud since 99% or all of them were automatics.
11-01-2017, 07:52 AM | #43 |
Wrong. That 383 crank (and rods) is a 400 crank. He never said the blocks were the same. The comparison is in the rotating assembly. No need to bore one out since it's already 17 cubic inches bigger than a 383. Yeah yeah, if the motor wears and needs rebuilt one day they don't take over boring as well. But plenty running around not needing that and they don't run hot. I don't think a 350 block can take the 400's bore either. Isn't the 383 max bore in a 350 with 400 crank?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-01-2017 at 07:57 AM. |
11-01-2017, 08:47 AM | #44 |
The possibility exists that you might run into a 400 block that shouldn't be overbored, but I personally haven't ever seen one that wouldn't take .030 and be healthy. A .030 overbore gives you 406 cubic inches, and there are a lot of those around.
The whole reason the 383 became popular was a scarcity of 400 blocks. Given the choice between the two, everything else being equal, I would take the 400 any day.
11-01-2017, 09:46 AM | #45 | |
400 flex plates will have an obvious weight on them , AND a dowel pin in the crank. THe dowel pin also identifies the crank as a 400 crank, and the pin is part of the balance of the crank. The problems folks have with 400's are almost always a lack of maintenance, inept engine builders or improper parts. There's no real big mystery, just big power potential if you get everything done correctly!!! My buddies 66 C10 would absolutely rip your head off. Tha build sounds sooo lame, it was awesome. He had a weak moment and sold that pickup around 1995, long story I didn't know about it, or I would have bought it. No telling where it is now. |
11-01-2017, 09:50 AM | #46 |
I love all the 400ci ive had. currently I have a 406, big solid lift cam, aluminum heads and intake. one key to making them really run is to change the rods and pistons. stock the 400 has a short rod and a tall piston. this combo is ideal for a good performer because the rod is trying to push the piston into the cylinder wall. from my experience if you go to a 5.7 rod or a 6.0 rod it really help. the longer rod straightens the piston out in the cylinder. the first engine I built I used a good set of used rods, new pistons, 041 heads and that thing was a lot of fun for real cheap. pulls way better than a 350 of similar spec. use a 4 core radiator if you can. i've never had any cooling issues
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
11-01-2017, 11:57 AM | #47 |
Are the rods on a 400 a bit shorter than other small blocks.....
11-01-2017, 12:00 PM | #48 |
11-01-2017, 09:18 PM | #49 | |
Just for what it's worth my cousin recently took out a fresh built 400 because of heating problems. But I just learned the 350 he put in is having the same problem so I don't think it was the motor. I keep telling him he need to put a by-pass hose from his intake to his water pump but he wont listen. The heater is usually the by-pass but if you do away with the heater you still need to run a by-pass hose so the water can flow through the heads. That will cure a lot of heating problems on these motors. |
11-01-2017, 09:30 PM | #50 | ||||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
