12-30-2019, 11:02 PM | #26 |
Re: Dunce's 61 SWB Custom
Nice job on the trans tunnel!!
01-08-2020, 11:26 AM | #27 |
Doing some repairs to the driver door jamb area, roof corner, and top inside/outside of the windsheild channel. Also filled in the heater cowl in the cowl area. They reproduce the outter panel under the front of the roof but not the inner for 60-63 that I could find so I used an inner repair panel for a later model and cut the ends off. If you don't need the whole length, it works just fine.
01-08-2020, 11:39 AM | #28 |
stellar work! Keep the pics coming!
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
01-08-2020, 12:09 PM | #29 |
Top Notch Work! Im also replacing lots of sheet medal on a replacement cab thats going on my 60 truck. 2 years later and still burning on it I dont feel too bad now watching all that massive work you have done on your 61.
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
01-08-2020, 01:31 PM | #30 |
Where did THAT bolt go?
Well done! That was a rusty one, but you are making it look great.
The Swiss Car Club......A drinking club with a car problem.... |
01-23-2020, 03:38 PM | #31 |
Update time...
-Finished up the upper windshield channel area -fixed some rust in the driver door jamb knee knocker area -deleted the gas filler hole on the cab -dash center speaker delete -delete heater control and ashtray from the dash.. will put a small vintage control there above a new custom autosound head unit with bluetooth etc. -With the vintage air unit, won't need fresh air from the cowl so usually I'd want to delete the grille from the cowl panel but did not want to lose the patina there so I chose to make a removable cover for the wiper arm mechanism intead. Fits under the panel and will seal to keep the air and water out of the cowl : ). -fixed someone's hack job under the gauge cluster where they added some aftermarket gauges. Won't need those small holes either but its back to a factory look now and I think I'll put the check engine light and bright indicator LEDs in those small holes. -Replacing door bottoms and small sections of the outter skins, again trying to retain as much of the original stuff as possible. Lots of measurements etc when doing the rockers and door bottoms paid off, everything fits damn nice and gaps won't be hard to dial in at all. -Front suspension coming soon and I have a column and hydroboost brake system to mock up along with the throttle pedal. |
01-23-2020, 04:03 PM | #32 |
Looks great! Your rust repair keeps giving me inspiration to fix my 63
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-24-2020, 11:26 AM | #33 |
Fantastic metal work! I agree with Christian, seeing someone else doing as much rust repair as I am inspires me to keep moving along.
03-11-2020, 04:08 PM | #34 |
Time for an update : ) Getting to more of the fun stuff now.
CPP Hydroboost brakes Scotts Hotrods IFS Fitting the LS3 Slight dash mod/fix for the radio/heater controls etc Gauge cluster Step notch out back with Quick performance 9 inch, 3.90 gears and disc brakes I have the original deluxe out wheel out for restore, just using an old 66 Nova wheel as a standin core support mockup, 69 camaro radiator, homebuilt shroud with dual 11 inch SPAL fans Made some 6x9 rear speaker sections and a place to mount the amp and PCM Test fit the vintage air AC unit Detroit Steel Del rays in bare steel... have some trim rings and chevy caps coming 315/30/20 rear tires and 255/30/20 up front - have room to go wider though. Doug Thorley tri Y headers fit this application near perfectly. Made some kick panels and put 5x7s where the vents used to be. |
03-11-2020, 09:55 PM | #35 |
60-66 Nut
Nice work
03-12-2020, 06:35 PM | #36 |
Man, there are several of you guys on here just crushing the rust repair jobs!
Nice group of parts & even nicer fab work!
07-13-2020, 05:13 PM | #37 |
Started putting my junk on youtube. Anyone interested can catch updates on this here:
EP1 https://youtu.be/T1fuF1z43xw EP2 https://youtu.be/4eITRNM5ibE EP3 https://youtu.be/I8NBo45xoWk EP4 https://youtu.be/FhpecmUKmpo |
07-13-2020, 05:56 PM | #38 |
Watched the 1st one. I'll check the other out when possible.
07-14-2020, 12:10 PM | #39 |
PART 5 : ) https://youtu.be/Z_fyBCpAAMY
07-19-2020, 10:49 AM | #40 |
DAMN your body work is impressive!!!
