12-27-2017, 11:33 AM | #26 |
Re: Just ordered my Holley Sniper EFI....
I have the FiTech on mine- had some initial problems with the fuel pump but have an in-tank pump now, and it runs beautifully, no pump noise, and looks old school. Very happy I did it.
Posted via Mobile Device |
12-27-2017, 06:12 PM | #27 |
I have the fuel pump mounted on the frame on passenger side. Mine had a fuel filter there, not sure if they all came that way. I just took the original fuel filter off and started there with the filter-pump-filter setup holley sent, then ran new high pressure hose up to the throttle body, then ran the return to the vent that is on the top of the tank also on passenger side. Holley supplies like 20 feet of hose with the kit I believe. Used the supplied clamps and insulator sleeve in the kit and strapped it right to the frame. I bought the sniper kit from one that advertises on here. Believe his name is Tommy Lee, his company is based out of OK I believe. I just got the spacer on summit but I'm sure he could hook you up.
71 GMC 1-2 ton 4x4 71 Chevy Cheyenne 2wd |
12-28-2017, 09:56 AM | #28 | |
12-28-2017, 01:46 PM | #29 |
Got my kit from Tommy also....close to finishing the truck but the install was easy
1972 Cheyenne Super..owned since 1978 1972 Surburban 4x4 1972 Cheyenne 4x4 3/4 ton.....sold 1972 Cheyenne 2wd...named Death Row |
12-28-2017, 02:12 PM | #30 |
12-28-2017, 03:19 PM | #31 |
TNT ....look in the vender area
12-28-2017, 03:21 PM | #32 |
ksbrktracer
12-28-2017, 04:10 PM | #33 | |
12-28-2017, 10:52 PM | #34 |
This may be the wrong question, but if I were to install one of these systems, gas mileage would certainly be one reason for it. I LS-swapped my first K10 (5.7/4L60E) and it got about 18-19 mpg. My current K10 with a 350/350 gets 10mpg. So, what kind of mileage are you guys seeing with either the Fi-tech or the Sniper?
Additionally, are you getting more power, and by roughly what percentage if so? I figure you gotta be, but don't know for sure. No way people are installing these just for ease of starting. Thanks! And I agree with one of the previous posters, we need some photos on this thread!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
12-28-2017, 11:05 PM | #35 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
12-28-2017, 11:07 PM | #36 |
Something tells me that might have to do with your usage of that extra power...
Thanks for the reply!
01-05-2018, 12:48 PM | #37 |
I decided to go with the FITECH system for a couple of reasons. First the cost and second my local performance shop had now down over a dozen FITECH conversions and has established a working relationship with the company. I was going to do the install myself but was concerned about dropping the rear tank myself since i decided to go with the reyrofit in tank fuel pump. I know it will run better than the carb but I'm really hoping to improve on the 6 mpg that this old 307 is getting! I'll post my results.
01-05-2018, 02:02 PM | #38 |
Im in for info also. I plan on going FI with my build too. Looking at Sniper because of Holley background. I have a question to you guys already running FI. How bad does the cam size affect the system? Meaning I would to love to use a mutha thumper cam but I believe it’s to much overlap which doesn’t have enough vacuum for FI. Any experience would be great.
01-05-2018, 03:05 PM | #39 |
I got the sniper master kit, just waiting to install it. Going on a 402 with alum heads and cam. I'll start an install thread when productivity kicks off.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
01-05-2018, 04:08 PM | #40 | |
01-10-2018, 12:00 AM | #41 |
Not sure if you've figured this out already, but I just noticed your question. No vent on a stock 67-70 tank, as the cap was vented. 71-72 trucks have a different tank - non-vented cap, and an Evaporative Emissions Control (EEC, smog regulations) vent system to a charcoal canister under the hood. Those of us with 71-72 tanks can use the additional vent fitting as fuel returns in some scenarios.
01-10-2018, 08:55 AM | #42 |
Good info applebmw! I have my block at the machine shop right now. I’ll call them and talk to them about cam vacuum and let you know bud.
01-10-2018, 10:11 AM | #43 | |
Our 39627128114 should get the job done for you. You can search this part number on our site And it will give you the full specs, etc... Regards, Isky Cam |
03-02-2018, 07:01 PM | #44 |
Just a quick update for anyone that is curious about the Holley Sniper EFI system. I have been running it for about a month now. It learned pretty quick and I have a much better cold start, idle and throttle response. Holley tech support has been very helpful with any questions that I have had.
