#26 |
Re: Tuff Country EX Ride springs
I modified the factory 73-up brackets. Ill take some pics in the next day or so. If I was to do it again, I would also use the 73-up front cross-member because it seems like it will bolt (rivet) right up to the 72-down frame rails.
I went for another long ride yesterday, and am amazed at the difference the anti-sway bar and springs made. The body doesn't lean anymore, and the braking is so much more controlled. I was always concerned about snapping one of the front leaf springs at the front perch because it just seems like a week area. Without the anti-sway bar, the axle could then move backwards and would most likely flip the truck. This probably explains why the 72s have that small bracket behind the spring to try and prevent that. With the anti-sway bar, it's now impossible for the front axle to shift backwards in the event of a spring failure. The piece of mind alone is worth the install. |
#27 |
Well, it's been 2500 miles since the spring install, and decided to see if the truck settled at all. Ride height seems to have settled about 1/2" from when they were new. Still the best improvement I've done on the truck so far.
#28 |
![]() Join Date: May 2015
FWIW..I just installed a Tuff Country 2 inch EZ ride lift and 33 inch tires. The pics show where I ended up at zero miles. I didnt take any before measurements
#29 |
![]() Join Date: Nov 2013
How is the ride with those springs?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#30 |
#31 |
#32 | |
Its a Truck Thing......
Did you have any issues with the tie rod mounting to the spindle after installation? Or did you not remove them? When I put my springs on, the tie rods were not hooked up. Tried to run the complete rod across and it hits the spring. No engine in mine yet. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#33 | |
