01-18-2018, 08:45 PM | #26 |
Re: To Big Block...Or Not to BBC.....
My vote!
1968 SWB Step Side, Big Block, 4L80E , Running! |
01-18-2018, 08:54 PM | #27 | |
However, I've become a real LS fan. They will return around 20 mpg in our trucks, maybe slightly more if you are real careful. I like the pix of the Corvette, always thought a Corvette motor in a truck would be cool.... Kind of like this.... |
01-18-2018, 09:13 PM | #28 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
"No replacement for displacement" Take it from someone who owns two LWB 72 C/10's that came with factory 350's. I dropped a 1969 L34 396 BBC in "Sally" two years ago and the WOW factor is STILL off the scale! Oddly enough, I use "Bellle" (cammed 4bbl 350 with a built 350 Turbo-Hydramatic, 3:73 Posi, 275/70R-16's) to tow "Sally" to show sand drag strips. "Sally's" 396 was bored .060" over to a 408 cubic inch BBC with a Comp 268HE cam, Comp roller rockers, Speed-Pro 22cc forged domes, hard seated 3964290 98cc closed chamber heads. 800cfm Ruggles Quadrajet on a Weiand aluminum intake. Built 350 "Super-Turbo" w/10" 3000rpm stall, beefed up truck 12-Bolt w/4:56 Eaton Posi...Very streetable and a blast! No mistaking that BBC sound either! https://youtu.be/_jXxaOqm36M?t=1m19s
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 01-18-2018 at 09:24 PM. |
01-18-2018, 09:47 PM | #29 |
How much is budget driven?
One thing to consider, is the power steering setup and motor mount setup will run you nearly $1000 unless you can find a cheap donor truck somewhere. Full disclosure, I just screwed together two different 427's. One for my 69 short, one for my 'vette. Big block is cool if the budget isn't primary driver. And they are cheaper than they used to be by a long shot since everybody wants an LS.
01-18-2018, 10:05 PM | #30 |
motor exploder
Well, if the 396/th400 is running and ready to go, it's an easy choice. If both the 400sbc and 396bbc need to be built, then do what your budget allows - they both offer the cubic engines that you'll need on your side to pull that truck around, plus you could sell the other two engines off to fund the one you build. The 350 would be my last choice. My personal preference leans towards big blocks - the low end torque and big time midrange is addicting. As you can see in my signature below, I have 2 BB's, a gen 1 sbc and a gen III (LS) sbc... These trucks just look 'right' to me with a big block under the hood.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
01-18-2018, 10:30 PM | #31 |
I vote Big Block.
Everybodys got an LS or a SBC. Be different and stand out from the crowd.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
01-19-2018, 07:14 AM | #32 |
My 67 short step has a 30 over 454 with a 4 spd and skinny tires it's a fun truck too drive( it's just a cool cruiser) but it drinks alot and I feel a lot of that power is a bit useless....but it is ALOT of tire twisting fun.
Another one of mine is a completely different animal. 71 k20 400sbc granny 4. The 4 sips compared too the BBC but it still pulls the heavier truck around with the feeling of the power is there if you need it. If I come across anymore 400's I'm gonna hide them in the corner, awesome engines. Neither are anything like the high winding 355 in my light car. I have too twist that one up too make it do what the others do at a relaxed pace. But it's also built that way.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
01-19-2018, 09:08 AM | #33 |
I’ll be going 468 in Walter with a 4L80e. I already have the complete running motor, accessories etc that came in a vehicle I bought a few years ago, so it’s a no brainer for me.
And the sound of a built BBC is unmistakable when you roll in...& lift that hood up you have the added “WoW” factor. Last edited by nlped; 01-19-2018 at 09:09 AM. Reason: Damn spellcheck |
01-19-2018, 09:48 AM | #34 |
what fun is owning a big block if you dont put it in something...isnt the principle of building a hot rod to use what you've got rather than writing a check for the latest and greatest?
1970 short step c10 leaf spring 454 |
01-19-2018, 01:46 PM | #35 |
350 to 402 conversion on my truck ended up being costly because of having to get all new motor mounts, accessory pulleys, new brackets etc. Re-using this stuff by staying small block saves a bunch of cash. I'm happy in the end though.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
01-19-2018, 02:14 PM | #36 |
no !
Stan 67 swb BLU MULE posted via flip-fone |
01-19-2018, 09:16 PM | #37 |
Many different ways to look at this situation.
What are you wanting to do, how much do you want to spend, and why? You can hot rod a small block 350, or build a IHRA stroker pro stock "mountain motor". Or you could go LS motor, from take out 5.3 with 225000 miles to crate motor LS-9 and add twin turbos. Remember all of these options can be ego driven. Most important thing is to build/ buy what you want, and HAVE FUN. All the best, Dirk |
01-21-2018, 10:13 AM | #38 |
Thanks Guys, some truly good thoughts here. I am a few months from retirement after 35 years at one employer and am planning for my glory days ahead. I still have my first car, my Dad bought me a 67 Camaro when i was 15, and you would freak at the number of motors , trannys and `12 bolts that thing has gone thru. While I really liked the 70 Chevelles, I wound up with all 69s.....still have six of them today. All of the big blocks that I collected and have hung on to, are ALL 396s for some reason.ha ha....no 454s. I also have a complete tuned port trans am with all the drive train that I was to swap some day....as well as a LS 1 engine, and about every cubic inch sbc they have made.
My daily work truck is my Dads 69 GMC truck he bought new when I was 12. Having gone thru 5 engines, it is approaching 1 million miles. After collecting and restoring, restomoding, Chevelles, Camaros, Impalas, Vettes I got bored and started acquiring Chargers, and Challengers. But now I got the hots to redo a 71 lwb that was a 350/350 when new. I picked this one up a few weeks ago and have been lurking here sucking up all the wonderful info many here have on all things considered on these trucks. This girly truck, which is what I call a truck with carpet in it, will be sporting the orange with white wide stripe between body moulding and white cab. My neighbor kids mother bought him a truck like this when I was 15 and I rode with him in it every morning to my first summer job in 1972....and have wanted one sense then. I want this one purty, but will be street driven and not a points correct restoration , not too concerned about gas mileage either. As I am entering the last 1/3 of my time here, I was just wondering out loud, what of my large stash of parts to use on this project. thanks to all who posted.....the posts seems to be leaning to a bbc....me too |
01-21-2018, 10:45 AM | #39 |
Amen! And Bandit, I too waited until retirement to "pick up" where I left off back in the early 70's...Girl-friend became a wife, she became a mother three times, I made a career out of staying alive 300 feet above the street. 45 years and $250,000.00 in child support later, I "picked up" Sally and Belle...They're old girls, dont get pregnant, but they sure do take all my money! That's why they're named after old girl friends...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 01-21-2018 at 11:05 AM. |
01-21-2018, 11:45 AM | #40 |
If you truck original was equipped and set up for a small block...then I am thinking the most economical route would be to go after a 383 or find a 400 sbc.
That way, you don't have the extra costs mentioned here regarding engine mounts, brackets, etc.....super easy interchange to put either of those in that truck and any future accessory can be found and had for pennies due to the economic and common nature of the SBC. The upside of the 383/400sbc route is that you get a motor that is going to produce more torque....although not as much as a big block. So here is the ultra/super big question.....what is your budget max for this? (that maybe should have been the first question....because we all get carried away with the 'sky is the limit' ideas, lol) All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
01-21-2018, 12:25 PM | #41 |
BBC and drive it like you stole it !!
01-21-2018, 12:48 PM | #42 |
Lots of variables - and answers to several questions may steer you in the best direction.
1) Did we establish that this is a C10? (and not a C20/30 Longhorn)? I may have missed it even though I read the thread - but I did so kinda quickly. If a C20/30, go with your 396/TH400 and enjoy. 2) What does "street driven" mean to you? (to some it means hairy burnouts and slamming on the brakes at the next red light). If you DON'T care to be doing burnouts in it, then skip the BBC route in a C10 (unless you just want one for sentimental reasons) - but it's not really necessary for a daily driver/runaround truck. It IS cool though . 3) For all your options, do you have all the pulleys, engine stands, etc (or, more appropriately, since it has the SBC stuff, do you have all the BBC amenities, pulleys, wp, brackets, engine stands, etc)? 4) 350 or 400 dilemma... I'm assuming you want to use what you have on hand since that's what you mention. If so, and you're not gonna do burnouts, and you just want to enjoy driving it, and it's not a C20/30 Longhorn, etc - I'd skip the 396/TH400 and just rebuild a nice 350 and enjoy it. 400 has more torque, but it comes down to whether or not you're comfortable living with the 400 sbc overheating myth or reality. I personally didn't like the design of the siamesed cylinders, however, myth or not, but folks have been driving .060 over 400 sbcs with no problems for decades, so it comes down to that personal decision for you. Of course folks that have never had one overheat will swear it is a myth - and those that have will never use one again. So it comes down to your personal comfort level. 5) Do you want to tow/haul or anything? If so, then the 400 and 396 are perhaps better options - and if you have the peripherals and brackets etc or don't mind spending the $ on them, I'd go with a 396/TH400 over the 400 sbc all day long. Just my 2 cents. Nice to have options isn't it? If you really just want a nice driver and are going to focus your main effort son your barn of Chevelles, then the 350 may be just the ticket, and would be very original-ish. Having said all that - if money isn't an issue, then I'd probably stick an HT383 in it (with some center bolt valve cover adapters so you can run original vc's, of course) and call it a day. |
01-21-2018, 01:49 PM | #43 |
Just a reminder...
There's no substitute for cubic inches! I have a 518HP, 585 TQ, 468 BBC in my 67 Cutlass. Wish I had the money for a 502.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
01-21-2018, 05:27 PM | #44 |
motor exploder
^ That's a FINE looking big block right there!
01-21-2018, 10:35 PM | #45 |
I dropped a 402 in my 64 4x4...
1964 BBC 402 4x4 |
01-23-2018, 01:52 PM | #46 |
jocko, I posted my truck as a c/10 and that may not be right. I thought you guys say longhorn for a long bed truck and the Chevy c/10 is the same frame as my GMC 1500 frame.....and that a C/20 was a 2500 frame....so I may incorrect with that.
Now several have stated the big block frame brackets are quite expensive and I have not looked those up yet but don t think that will be a problem. Also, I have all kinds of brackets for big blocks and just assume most all those that work for my Chevelles will work when placed in the 71. I am also assuming that the bb swap into a sb spot will not require any major suspension part changes. Like if you put a bb into a Camaro with sb springs, your suspension will pretty much bottom out.....so new correct springs are a must. I do want to retain power steering and brakes. It s time to get the engine and tranny done now while I m not on a "fixed " income, yet....lol. |
01-23-2018, 09:41 PM | #47 |
Go big block for the WOW factor and to be different.
01-30-2018, 08:47 PM | #48 |
No comment needed, the pic says it all
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-30-2018, 10:39 PM | #49 |
Getting close!
01-31-2018, 12:02 AM | #50 | |
BlahBlahBlah
That is a good looking set up. I really like the serpentine, much nicer (IMO) than the billety stuff.
