01-31-2018, 11:47 AM | #26 | |
Re: fuel pump and tank
01-31-2018, 11:58 AM | #27 | |
01-31-2018, 12:53 PM | #28 |
can I use the 5th gen pump and go up to intake and run return back to tank so I can use shorter pump, just wondering
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
01-31-2018, 01:55 PM | #29 |
In this case no. The 5th gen pump with the appropriate hardware from Vaporworx already regulates the fuel pressure and allows you to dead head the fuel rail. If you were to run a return line you wouldn't build fuel pressure. The fuel would just flow through. One of the reasons I like the Vaporworx system is because there is no longer a need to run a return line making the install much easier to me in my eyes. Even with the corvette regulator/filter you need to run a return line from the filter back to the tank. I'm confused on what you mean using a shorter pump?
01-31-2018, 03:02 PM | #30 |
Post Whore
ls1nova...."This is another reason I dont like blocking the return line. I'm pretty sure he's talking about the line on the rail, and a little miscommunication going on here. If someone tried to use these on the rail, it would only be a matter of when, not if there will be a fire."
I agree 100%.....sometimes i fail to read between the lines.....100% on not using these caps on high pressure fuel rail....never ever...I thought he was referring to the unused return port on the tank....if he was using a internal pump on my return fuel rail I used a pushlok to -an and then put a -an cap on it and its fine....my vett filter/reg is where my return to tank comes from
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-31-2018 at 03:10 PM. |
01-31-2018, 08:52 PM | #31 | |
01-31-2018, 09:11 PM | #32 |
I have my 2002 Tahoe pump compressed to 9" and I dont think its all the way down, but if it is, you could probably trim off another half inch I would think.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-31-2018, 09:17 PM | #33 | |
02-02-2018, 12:44 PM | #34 | |
