Old 11-17-2018, 04:43 PM   #26
Bonestock3ott
Re: Neutral Safety Switch/Backup Lights
You need to run 12 volt fused power into one terminal and then attach the wire you ran to the reverse lights to the other terminal. The switch is just a simple single pole switch . If the lights are on all the time the switch will need to be adjusted or possibly the wires will need to be reversed on the switch. Hope that helps
Bonestock3ott is offline   Reply With Quote
Old 11-18-2018, 12:53 AM   #27
ezrider01
Junior Member
ezrider01's Avatar
Absolutely does...duhhh.....I totally forgot about the 12v source. Thanks for the help!!!
My Classics:
'72 Corvette Stingray
'69 Chevy C10 (WIP)
ezrider01 is offline   Reply With Quote
