03-03-2018, 12:40 AM | #26 |
Re: Gear vendor's with 3:54 rear gears and th400?
WE purchased a GV for the 454/400, 3.73 gears, 72 Suburban my son in law is building.
I'm anxious to see how it works.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
03-07-2018, 05:58 PM | #27 | |
03-08-2018, 06:51 AM | #28 |
The 700R4 gear ratio spread is poor as well. The big drop in rpm going from 1 to 2 is brutal.
Gear vendors is an amazing product. They shift firm, quick, and they are quiet. Not a single bit of noise cruising or under load. If you can't run a 4L80E (first choice for me) then a TH350/400 and Gear Vendors is the way to go in my opinion.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
03-08-2018, 08:53 AM | #29 |
Cost?
Brian Ritter |
03-08-2018, 09:23 AM | #30 |
I don't want this to turn into a cost v's 700r4 thread guys. There are plenty of those. I will never put one in my trucks. I am simply wanting info on gear ratios and the gv Overdrive and pros and cons of adding one. Thanks.
03-08-2018, 10:13 AM | #31 |
Ive got one behind a TH400 and 402BBC. But that is with 4:10 gears.
If I had 3:54s I would not add a GV, it would be too much reduction. If your thinking about fuel economy it will never work out. With the GV on you are driving another gear set and it becomes a wash. With 4:10s on the highway running 4500rpm was a little much. The GV reduced it closer to 3500 and I'm happy with that. Run the 3:54s and if you don't like them swap them for something else. I think you will be happy with them. The cost of the drive shaft mods alone will just about pay for a new gear set.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
03-08-2018, 10:24 AM | #32 |
I am going to change my gears at this point I believe. I am going to add the gear vendors but you are correct 3.54 is too low. I'm building this truck to have fun in so fuel mileage isn't really a major concern. I like that I can get my rpms down and have it be a bit quieter in the cab and save my engine some wear on the highway. I'm just debating between 3.73, 3.92, or 4.10s. Would liven up the bottom end and give me a little on the top. My engine is an 275-300 hp 327 stock but will be rebuilt to same specs as stock.
