Old 02-20-2018, 01:37 PM   #26
_Ogre
_Ogre's Avatar
Re: 57 Rear axle swap
check the offset and width of these good deal wheels
need 4-5'' on a 8'' rim for a 60'' axle to fit under the rear fenders
shop air compressor timer
Old 02-20-2018, 04:25 PM   #27
buggy5872
buggy5872's Avatar
I used a dana 44 out of a 75 CJ5 jeep ($100 bucks). I put disc brakes on using Suzuki samari front rotors and Lincoln continental calipers. Might have $300 in it total. It is good for tires up to 18.5 wide that do not rub on the outer wheel well. You will need to make tubs for the inner wheel well. I made a 4 link set up but you can use the front spring hangers and put the springs inline under the frame rails to be able to use it on the cheap. The pic is with 15.5 wide tires
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
