02-27-2018, 08:02 PM | #26 |
Re: Any Solutions to 55/56 Hood Oil Canning
apache hoods came with the brace down the center
it still flexes quite a bit anytime you get much over 80 mph
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-17-2018, 09:15 PM | #27 |
Finally was able to install my fix for the hood oil canning. Appreciate everybody's help and ideas. Here's the final solution. Fits right up against the hood, used some dabs of silicon along the way to provide some vibration dampening.
03-17-2018, 11:18 PM | #28 |
Right on, hopefully what you dabbed between them stays flexable. From the factory they use a soft foam because if what you put "glues" the two together you will end up with a "ghost line" on the top that you will be able to see.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
03-18-2018, 05:27 PM | #29 |
Thanks. It fit really well. Yes the silicon is a soft when cured. Didn't use that much, just enough to eliminate any vibration.
03-18-2018, 05:30 PM | #30 |
Cool!
Brian
03-19-2018, 08:29 AM | #31 | |
Jim |
03-19-2018, 09:49 AM | #32 | |
Brian
03-19-2018, 12:28 PM | #33 |
