Old 04-03-2018, 12:35 PM   #26
Peanutbutter
Re: 1972 C10 2wd M20 wont go into gear
Did you see the video on the news of the 4 mountain lions on the jogging trail in Boulder, need more of them.
Peanutbutter is offline   Reply With Quote
Old 04-03-2018, 12:39 PM   #27
ratman90
Yes, especially since they want to ban semi auto rifles. Maybe after a few get eaten, they will think otherwise.
1972 C10 LWB 2WD
307 4 speed
Rescued from Field July 2017
ratman90 is offline   Reply With Quote
Old 04-03-2018, 08:30 PM   #28
ratman90
Okay here is a picture or two the white charging cord is towards the seat.
1972 C10 LWB 2WD
307 4 speed
Old 04-03-2018, 09:15 PM   #29
mongocanfly
Post Whore
mongocanfly's Avatar
if I'm seeing it right it looks jammed...take a big screwdriver and get all 3 shifters lined up...you'll have to pry em into place...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-03-2018, 09:17 PM   #30
ratman90
Man I can't even tell what you're talking about from that picture I need to find some normal pictures along and go back to look at that thread.
What this happened because there was not oil in it?
1972 C10 LWB 2WD
307 4 speed
Old 04-03-2018, 09:26 PM   #31
mongocanfly
Post Whore
if you look down in the shifter hole you'll see 3 notched shift levers...they should all be lined up...here's a pic of a clean one so you can see em better...but this pic is in gear...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-03-2018, 09:28 PM   #32
mongocanfly
Post Whore
are you saying the trans didn't have any oil in it? if that's the case you may have serious issues...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-03-2018, 09:31 PM   #33
ratman90
Not 100% sure of level. Does not leak or drip. 90k miles so i did not stress about it. Had many other projects on the truck since july.
1972 C10 LWB 2WD
307 4 speed
Old 04-03-2018, 09:32 PM   #34
ratman90
Here is a video in my google drive. See if it works.
https://drive.google.com/file/d/11va...w?usp=drivesdk
1972 C10 LWB 2WD
307 4 speed
Old 04-03-2018, 10:06 PM   #35
ratman90
What is that button or Rod looking thing on the left in my picture?
1972 C10 LWB 2WD
307 4 speed
Old 04-04-2018, 04:01 AM   #36
jjzepplin
jjzepplin's Avatar
What does the bottom of your shifter look like? Please post a pic. Your shifter has a small button on the bottom that goes in those slots. All the slots need to be aligned to be in neutral. The "Button" Should move freely between 3 aligned slots when in neutral if I remember right. Start with aligning that one on the right with the one in the middle.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-04-2018, 10:22 AM   #37
mongocanfly
Post Whore
I can't tell what that is in the pic...lotta glare...and grease/oil....make sure its not the end of your shift rod broke off...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-04-2018, 02:30 PM   #38
ratman90
Yeah when I initially pull the shifter out, I thought about that tab. I was not sure if I was hopeful that it was broken off so if he needs a fix or what. But it appears to be there.
1972 C10 LWB 2WD
307 4 speed
Old 04-04-2018, 03:48 PM   #39
jjzepplin
jjzepplin's Avatar
How hard was it to remove the shifter? It could have just come loose and raised up enough to come out of the slots. Could just need some work to the shifter.
Old 04-04-2018, 03:50 PM   #40
ratman90
For some reason is telling me the security token will not let me upload a picture of the shifter. It has the little T on the end that I see on new shifter. Shifter came right out once I took off the lock ring with channel locks.
1972 C10 LWB 2WD
307 4 speed
Old 04-04-2018, 03:55 PM   #41
jjzepplin
jjzepplin's Avatar
Sound like it could be ok. Is the piece that goes into the slots at the end loose?
Old 04-04-2018, 03:58 PM   #42
ratman90
Now it seems fine looks like it's Walden Honor made part of the rod itself if memory serves correct. I'm just trying to figure out how I'm going to crawl up underneath there with enough light and enough space for a screwdriver and my face to see down inside there to line up those shifting rails
1972 C10 LWB 2WD
307 4 speed
Old 04-04-2018, 04:01 PM   #43
jjzepplin
jjzepplin's Avatar
It's not too hard. Go for it.
Old 04-04-2018, 04:42 PM   #44
ratman90
So when I get these shift rails all aligned my transmission will go back to shifting normally?
1972 C10 LWB 2WD
307 4 speed
Old 04-04-2018, 06:00 PM   #45
mongocanfly
Post Whore
can't say for sure but its one step in the process....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-05-2018, 05:18 PM   #46
Tom
driving is in my blood
Tom's Avatar
This is a great chance to swap in an actual M20 like I did when my sm465 went out. The sm sucks anyways.
Old 04-05-2018, 06:14 PM   #47
Macdaddy1
I have an M20 for sale if you are interested.
Pat
Macdaddy1 is offline   Reply With Quote
Old 04-07-2018, 09:08 PM   #48
ratman90
Talking Re: 1972 C10 2wd M20 wont go into gear
After many attempts to try and use my phone to take video with the flash on so i could see, i got those things aligned an am running again!
Sorry for the delays between post trying to coordinate between jobs and 4H and everything else. I now need a chiropractor appointment for crawling up underneath there at the same time.
My question is why does it do that? How does he jump out like that?
1972 C10 LWB 2WD
307 4 speed
Old 04-07-2018, 09:56 PM   #49
mongocanfly
Post Whore
glad that was your problem and its fixed....its just one of those things that happens sometimes....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-08-2018, 06:02 AM   #50
jjzepplin
jjzepplin's Avatar
My guess is wear on the shifter. It is held in by spring loaded force. We know how to fix your problem because we have been there and done that. The first time I pulled a SM420 I got 7 stitches. A good chiropractor is nice to have. Push down real hard on your shifter in neutral and see if it moves down any . This "play" can be the issue. You may have a worn out ball and socket on the pivot of your shifter. Good to hear you did not have to pull it! Happy motoring!
4speed, m20, muncie m20
