Old 03-26-2019, 11:40 PM   #26
First c10
First c10's Avatar
Re: Dakota Digital HDX with the OBDII BIM module
I made my own and it doesn’t work. I had to unplug one to use the other. I just installed my hdx set up and just unplug when I have to tune the truck.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-27-2019, 10:53 PM   #27
thehata1
Thank you for the feedback.
thehata1 is offline   Reply With Quote
Old 04-09-2019, 02:44 PM   #28
solidaxel
solidaxel's Avatar
Question about the BIM.
Have you connected a scanner to your OBD2 port to verify that it works OK? Also, you need to make sure the BIM is set to read the "J" protocol. It should work regardless if the engine is running or not as long as you turn the key on.
Weare having problems with the BIM connected to the OBD the engine will start and run for a minute or two and then stalls.
Unplug the BIM and all is good.
Do you think the "J" code is the problem?
Sorry for the hijack
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-29-2019, 10:24 AM   #29
saon
i just had the same issue on a ls swap. dakota digital has a fix. when i called they were like " oh yes, send it back" so they updated the calibration in it to fix it. said the revision 1.8 needed updated to 1.9 in the bim.
disclaimer, i expect it back tomorrow or wednsday to verify the fix.
problem was
truck ran perfect, plugging in the bim caused it to stumble randomly at idle and try to die flashing the check eng lite. un plug bim runs perfect.
saon is offline   Reply With Quote
Old 04-29-2019, 10:43 PM   #30
stevenbear72
stevenbear72's Avatar
Following, as I will most likely be buying the hdx or vhx kit soon once I see who has a better deal on them
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 04-30-2019, 08:01 PM   #31
Bluerust
Not quite the HDX, but I installed a VHX gauge system for my '86 with the Bim module late last summer. I have a PSI harness and PSI supplied E38 ECU/T42 TCU(4L80). I used an OBD splitter from Amazon. The gauge panel works great so far, knock on wood...
Hooking a scanner to it was interesting but worked. The code readers I have did not completely connect when I turned the key on initially. When I turned the key off it finally displayed codes and let me clear them. I think the scanner worked after turning the ignition back on at that point too. I've forgotten some details.
I had a misunderstanding with PSI when I talked to them about using the BIM module. I have an L96 6.0 with VVT. The PSI harness has the stock oil pressure sensor plug and the Bim module uses it. A PSI staff member had originally told me I needed to add the dakota digital oil pressure sensor to the engine also, which I did at first, but it wasn't needed after talking to a different PSI staff member during a different phone call.
Josh
1986 K30 L96/4l80/205
http://67-72chevytrucks.com/vboard/s...d.php?t=784999
Bluerust is offline   Reply With Quote
Old 05-01-2019, 10:29 PM   #32
72MARIO
72MARIO's Avatar
I just found out i have the same problem with my suburban stalling.
Nice expensive fix for me. Just send it bavk to us...great if only I was in the US wouldn't be a problem.
problem was
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-29-2019, 11:40 PM   #33
TA_C10
TA_C10's Avatar
Anybody know what is included with a 2003 ECM? Does it provide all of the following that the BIM can use?
VSS
TACH
OIL Pressure
Water Temp
Trans Temp
Gear indicator
Cruise Control light on dash
Check Engine Light
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 12-30-2019, 09:30 AM   #34
nsb29
nsb29's Avatar
Why not just add an additional OBD 2 port ?? If you don’t want to hardwire it
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 12-30-2019, 01:34 PM   #35
TA_C10
TA_C10's Avatar
Huh? Not a question of obdII ports. It's a question I need to figure out for customizing a new AA harness. Removing wires in bulkhead I don't need.
"It's only money".
Old 12-30-2019, 04:19 PM   #36
jocww
I have the rtx theyre pretty sweet
My build a 49 5 window ls1 4l60e on a TCI chassis
http://67-72chevytrucks.com/vboard/s...d.php?t=754926
My travel blog
The Wong Winding Road-Adventures of The Chinese Cowboy
https://thewongwindingroad.blogspot.com/
jocww is offline   Reply With Quote
Old 12-30-2019, 08:52 PM   #37
nsb29
nsb29's Avatar
It was in regards to post 19 wasn’t paying attention didn’t realize there was page two
Old 01-01-2020, 10:51 PM   #38
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I have the DD RTX too. Not installed yet, but hopefully it goes OK. I'm somewhat intimidated by all the wiring of the PCM harness, AA body harness and RTX.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-01-2020, 11:36 PM   #39
jocww
They touted as easy.... yea right took my installer 6 hours to do it
My travel blog
Old 01-02-2020, 12:00 AM   #40
TA_C10
TA_C10's Avatar
I'm doing it now. I did my own engine harness, integrating it with a new AA harness as well. I will have more detail on my build thread soon. It's time consuming but not hard. I'm relying heavily on LT1swap.com for all the diagrams and a few members here for help. It's been awesome. Hope to fire it up this weekend if all goes well.
If you have the time, I highly recommend it. All the information is here you just have to organize it.
I'm doing the RTX gauges with the bim module so it's really gonna be that much easier.
"It's only money".
Old 01-02-2020, 11:09 AM   #41
derotoreut
derotoreut's Avatar
I'm also integrating mine with the AA Classic Update harness. Thanks for feedback. I'll check out your build thread.
~ Dan
Old 01-03-2020, 10:01 AM   #42
saon
VSS
TACH
OIL Pressure
Water Temp
Trans Temp
Gear indicator
Check Engine Light
on mine it showed
VSS
Water temp
Trans temp
gear indicator
Tach should show up but i ran the white wire from the ecm to the bim
check engine light i also ran the tan mil light from ecm to the bim
i didnt have cruise so i dont know if the light shows up.
oil pressure is not shown. i had to run the DD sender unit and wiring.
also wiring in a 2nd aldl connector doesnt work. when the DD is plugged into
1 port it wont allow a scan tool (gm tech 2) or a tune tool (hp tuner or efi live) to communicate with the ecm. you HAVE to unplug the DD before trying to communicate with the ecm anyway.
this is just my experience on a 411 warren pcm which i have done a few swaps with.
Old 01-03-2020, 10:44 AM   #43
TA_C10
TA_C10's Avatar
on mine it showed
VSS
Water temp
Trans temp
gear indicator
No oil pressure?? That's not cool. What about a 2005 PCM? Will that show oil pressure? The PCM/harness has a oil sender so I feel like this should be displayed through OBDII/BIM.
"It's only money".
Old 01-03-2020, 05:31 PM   #44
akdg87
akdg87's Avatar
anyone have issues with their gauges cutting out? I have the BIM with VHX in my pickup. High RPM accel 'power' them down and they restart. Its only the gauges run through the BIM module that have seem to have this issue. Using the 0411 PCM as well. Just kinda frustrating cause i cannot see the rpm or speed when flooring it.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 12-02-2020, 01:53 AM   #45
General23cmp
Did you figure this out?
General23cmp is offline   Reply With Quote
Old 12-02-2020, 10:58 AM   #46
rodstored-72
chevy truck fan
rodstored-72's Avatar
I just placed my order for the gauges & the BIM module (MCB MATT). I will be installing into a '86 C10 with a 2013 4.8 LS. I am utilizing the factory harness & underhood fuse box. it is a stock daily driver setup. I will be following along to see what I need to watch out for.
rodstored-72 is offline   Reply With Quote
Old 12-02-2020, 11:37 AM   #47
TA_C10
TA_C10's Avatar
I forgot about this thread. So I have my gauges installed with BIM module. I got the RTX model for my 70 C10. They are awesome. And for my update to the question I asked above, I got everything from the stock PCM/ECM. I ended up with a 2003 6.0L PCM actually, the harness I rebuilt was from a 2005. And I "DO" get oil pressure from the BIM, I also get Trans Temp as well from the 4L60E as well.
FYI I followed LT1SWAP.COM videos to rebuild my harness. It's not that bad to do, you just need to go slow, take notes, and be thorough with the wiring and connections. If I ever do this again, I will extend the harness next time so it would relocate into the cab.
Here is quick video I did a couple months back.
TA_C10 Dakota Digital RTX
"It's only money".
Old 12-02-2020, 11:41 AM   #48
skyphix
EDIT: Nevermind - seems you got oil pressure, which is pretty awesome.
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 12-02-2020, 12:01 PM   #49
TA_C10
TA_C10's Avatar
I saw your original reply that I would have to add the wiring to the dash. I think because I rebuilt my own OEM harness, following LT1SWAP.com instructions, and used his wire maps on his website, I made sure I pinned that out and added the wire(if it wasn't already there). And maybe the 2003 6.0L PCM has the Oil sender provisions. However, this was a year ago so I may be a little hazy on the exact reference here, but doing my research, all these computers were usually the same blueprint with different tunes so I think with a change to PCM tune you can turn the oil sender feature on/off in all these models. Then if the harness didn't have the wire, you just add it.
"It's only money".
Old 12-02-2020, 02:51 PM   #50
Thealien
Thealien's Avatar
I have been waiting 2 months for my RTX gauge set up, everything is on backorder! I will be using the OBDII BIM and the OBDII cruise control module. I hope it all works with a quality OBDII splitter (I bought the AMP research one that is supposed to be pass through). I "hope" it all works. A lot of money for a gauge cluster when you add in all the modules.
