Old 08-05-2018, 12:53 AM   #1
72cs20
Project 1966 K20 adventure rig
Here is the beginning of my effort to put together a cool back country travelling 66' K20. Right now I'm in a parts search and acquisition phase. Things like later style axles, power steering, update the brake system and bigger fuel behind the rear axle to start off. When I do the axle swaps I'll also rebuild the suspension. Then complete new wiring, interior work and more than likely Vintage Air.
That is the plan overview. The subject -
Right now I need to get the truck to drive and handle safely so I can actually use it. The first problem to be tackled is the worn out driver side lower knuckle bearing. So far I've gotten the knuckle assembly torn down and ready for the new parts, which should be here early this week. The upper bearing seems to be in good shape, but both will be replaced.
Knuckle dis-assembled and ready for new bearings -
Name:  Knuckle bearing repair.jpg
Dis-integrated lower bearing -
Name:  Lower knuckle bearing.jpg
Along with this repair, I'll be setting up the power steering conversion for use with this closed knuckle axle. Then it will be an easy change over when the open knuckle axle goes in.
More soon...
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
