Old 10-28-2018, 09:49 AM   #26
6t7c10
Re: Andys 68 c10
I had to replace the cowl on mine too, not a fun task. Mine didn’t fit well at all.
6t7c10 is offline   Reply With Quote
Old 10-28-2018, 09:53 AM   #27
Andyking1203
Re: Andys 68 c10
Mine fit well on the passenger side, the drivers side isnt as close, but nothing that a little hammering while hot wont fix, I'm glad a chose this part as the first to install, most of it wont be seen once it's all together!!!
Andyking1203 is offline   Reply With Quote
Old 11-02-2018, 05:54 PM   #28
Andyking1203
Re: Andys 68 c10
Managed to finish the cowl and started fitting the firewall... a few pics.. starting to look like a truck again!!!
Old 11-06-2018, 08:23 PM   #29
rjs53
Re: Andys 68 c10
Nice work man.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 11-06-2018, 09:06 PM   #30
Andyking1203
Re: Andys 68 c10
Originally Posted by rjs53 View Post
Nice work man.
Thanks, still a long ways to go, hopefully get the firewall atleast tacked this weekend
Old 11-07-2018, 06:31 PM   #31
Andyking1203
Re: Andys 68 c10
Test fit of the firewall and Got it all welded in today.. easier then I thought it would be!!! Next is the floor and inner kick panels!!!
Old 11-13-2018, 09:46 PM   #32
Andyking1203
Re: Andys 68 c10
Havent done much, trying to get a better heater in the garage... being a average of below 40 degrees during the day kinda poops on my ambitions!!!
Old 11-16-2018, 04:15 PM   #33
Andyking1203
Re: Andys 68 c10
Got the floor cut out today, a bunch of prep work and then putting the new one in!!!
Old 11-22-2018, 09:18 PM   #34
Sparky dave
Re: Andys 68 c10
Nice work Andy can’t believe you can get trucks that cheap. Even scrap trucks are doing 4-6 thousand uk pounds over here. Think you should send me some over to sell ha ha
Sparky dave is offline   Reply With Quote
Old 11-23-2018, 09:39 AM   #35
Andyking1203
Re: Andys 68 c10
Thanks dave.. it's been a fun project so far.. and it's only the beginning!!! I think the reason I got the original 72 so cheap was because it was a life long friend who had it, plus he was hard up...
Old 11-24-2018, 01:47 PM   #36
Andyking1203
Re: Andys 68 c10
So plans have changed for the motor and trans, another friend of mine has a 406 sitting, and a 400 turbo trans built to go with the motor, and a 2800 stall converter... should move the truck down the road nicely!!! Not sure why the trans pic is upside down...
Old 11-24-2018, 08:28 PM   #37
6t7c10
Re: Andys 68 c10
That’s going to scoot right along!
Making good progress
Old 11-24-2018, 08:54 PM   #38
Andyking1203
Re: Andys 68 c10
Thanks, Gonna hang the cab monday morning and hopefully start getting it ready to accept the floor pan... the 406 is about 650hp
Old 11-26-2018, 10:41 AM   #39
Andyking1203
Re: Andys 68 c10
Hung out in the garage this am, with the cab..... floor to be going in soon!!!
Old 11-30-2018, 06:04 PM   #40
Andyking1203
Re: Andys 68 c10
Made a little progress today.. replaced the inner kick panels, both where equally as bad.. plus got the inner rockers cut out, in prep for the new floor pan to go in.
Old 12-01-2018, 03:49 PM   #41
Andyking1203
Re: Andys 68 c10
Made HUGE progress today!!! Just gotta weld it in!!! I'm a little excited!!!
Old 12-01-2018, 03:51 PM   #42
Andyking1203
Re: Andys 68 c10
The pics...
Old 12-01-2018, 04:53 PM   #43
rjs53
Re: Andys 68 c10
Your on yur way! Next the rockers and then mount it to the frame
2003 Dodge 2500
1969 C10
Old 12-01-2018, 04:54 PM   #44
Andyking1203
Re: Andys 68 c10
Rockers and cab corners.... to cold up here to do the filler work.. that'll have to wait till spring..
Old 12-07-2018, 06:55 PM   #45
Andyking1203
Re: Andys 68 c10
Hate the fact that most of my pics come out sideways or upside down...
Anyway, made some progress today on the passengers side rocker and cab corner. Also test fit the doors and fender today.
Old 12-14-2018, 07:18 PM   #46
Andyking1203
Re: Andys 68 c10
So I made a little progress today.. here's a few before and after photos
Old 12-22-2018, 10:16 AM   #47
Andyking1203
Re: Andys 68 c10
Made some progress yesterday, got the passenger rocker tacked in, and cab corner on. Cab corner fit like crap.. hopefully the grinder will save me a little.
Old 12-23-2018, 10:27 PM   #48
rjs53
Re: Andys 68 c10
Your on the down hill run for this. Lots of work left but the time consuming Bodywork gets done and its smooth sailing after that.
2003 Dodge 2500
1969 C10
Old 12-24-2018, 12:05 AM   #49
Andyking1203
Re: Andys 68 c10
Cab is almost done!!! Still have doors (minor), fenders, and entire rear bed to do.. cant spread filler up here this time of year!!!
Old 01-01-2019, 08:54 PM   #50
Andyking1203
Re: Andys 68 c10
Haven't really done much over the holiday.. it's been really cold here lately!!!
But what has happened, I found some more rust in the passenger side door jam up by the roof (dam mice)!! So I cut out and replaced that.. wasnt to bad... also been sanding all the 50 year old paint off, also do to the larger hp motor I'm putting in the truck I have decided to 4 link the rear with coil overs, and a complete new front end from no limit. I messaged rob with a bunch of questions and got response the same day!! ������. Also adding in a frame stiffening center section from porterbuilt.. a lot then I expected to do to the chassis but it seems that I might as well do it now vs wishing I did once it's all together. Just a little update
