Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 11-17-2019, 04:29 PM   #26
Mr_Rich
Mr_Rich's Avatar
Re: 1999 Trans Am 5.7 6 speed
Originally Posted by jjzepplin View Post
I am going to need some help on this one guys. Oh it had a new clutch for sure and a B and M shifter. One broken exhaust manifold bolt busted flush with the manifold so some is sticking out of the head. Might be able to get it.
I like ARP bolts in this instance for replacements. If the the bolt is busted flush you might be able to start a hole with a Dremel tool and then use a reverse twist drill bit spinning clockwise in the drill and it will spin right out. That procedure worked for me. A Dremel tool is one tool I really like a lot. It was a lot easier to use a small grinding bit to center a hole for the reverse drill bit I used.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 11-17-2019, 04:41 PM   #27
jjzepplin
jjzepplin's Avatar
It is broken off flush with the manifold so about 1/4” should be visible once the manifold is removed. I usually give the bolts a good stiff bang with a punch before I try to remove them. So the rat should come out fine...haha!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
