Old 10-10-2019, 04:50 PM   #26
buffydores
buffydores's Avatar
Re: Squarebody 73-87 Brake Upgrade
I found plenty. I just changed my mind. My middle boy wants a square body suburban when he gets old enough. He's 10. In a couple of years, I'll get one and start working on it with him.
Old 10-10-2019, 04:52 PM   #27
buffydores
buffydores's Avatar
Originally Posted by Ski-me View Post
Nice info and thread. Are you saying a nice improvement over the original? I'm also running 35's and would be nice to slow it down a bit better.
Definitely do it. It's cheap. It works. I love these EBCs Ultimax 2 pads.
Old 10-10-2019, 05:09 PM   #28
Ski-me
Ski-me's Avatar
^^^ Cool, thanks!
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 10-11-2019, 01:56 PM   #29
1968k20
1968k20's Avatar
I just picked up an 72 k10, 6.2, barn doors!
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 10-11-2019, 01:57 PM   #30
1968k20
1968k20's Avatar
Suburban
Old 10-28-2019, 03:39 PM   #31
Ski-me
Ski-me's Avatar
Did you touch your master cylinder? I'm debating about swapping in a new one now.
My current MC is a 1-1/8" bore (18M217 or 19176456). Wondering if I went to a 1-1/4" bore (18M422 or 19176314).
My pedal still goes almost to the end when braking so think I may need to also replace my MC. New SS lines to calipers and also a new Vacuum Booster, from a few years ago.
My Blazer has the RPO code JB5.
- Jeff
Old 10-28-2019, 03:43 PM   #32
buffydores
buffydores's Avatar
I did not change the master cylinder.
Old 10-28-2019, 03:47 PM   #33
Ziegelsteinfaust
A larger bore master cylinder will give you more brake at any one point of pedal travel. It will also be firmer due to displacement of said fluid.
It all comes down to personal taste. On how you like your truck set up
On my Camaro I used a smaller bore master to get more progressive feel out of it when I actually get to race it. Making corner braking much safer.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-28-2019, 03:49 PM   #34
Ziegelsteinfaust
Wilwood makes a nice aluminium caliper for C10's. Its pricey, but looks good behind the right wheels.
Old 05-05-2020, 12:27 AM   #35
Morgsie
Does anyone know if these 3/4 calipers are "low drag"? The 3/4 ton uses a cast master cylinder and my understanding is none of the squarebody cast iron master cylinders were quick take up. Which would mean the calipers are not low drag?
Morgsie is offline   Reply With Quote
Old 07-05-2020, 12:32 PM   #36
naphtali5725
naphtali5725's Avatar
i know, older thread... anyone here use these calipers with Mcgaughys 2.5 drop spindles with 1 1/4 rotors?
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 01-07-2021, 03:37 PM   #37
chappys4life
Looking to do this on my 78 and hoping to verify the part numbers:
- napa total eclipse 3 5/32" piston calipers CAL SE4674 & CAL SE4673
- napa pads CAL SE4674 (should i use ebc ultimax 2's? cannot find the right part)
- napa brake lines UP 38065 & UP 38066
- 2 banjo bolts for calipers
chappys4life is offline   Reply With Quote
