02-22-2019, 07:55 PM | #26 | |
Re: 1980 Stepside gmc
Trey Oney Last edited by bagged01extcab; 02-22-2019 at 11:29 PM. |
02-22-2019, 11:09 PM | #27 |
Today I finished body working the passenger door and glove box. I got them primed with evercoat super build. This stuff is awesome! If you haven’t tried it, you should!
That’s all I’ll get done till probably next week, as I’m headed to lst tomorrow and have a busy work schedule this next week
Trey Oney |
02-24-2019, 02:22 PM | #28 | |
Not dogging your engineering, just trying to understand it as I am about to do mine soon. I really like how you mounted the bags with the cross bar. I was thinking of doing a wishbone to keep the axle square under the truck and give it another point of strength with the two link - and it won't allow the axle to go from side to side like a pahhard bar does. I had that problem with my 67 c10.
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
03-09-2019, 11:35 PM | #29 | |
I copied and pasted the above from an online explanation. I call it a track bar but the proper term is a diagonal bar. Look at phat phabz as he uses it on his rear suspensions also
Trey Oney |
03-09-2019, 11:57 PM | #30 |
Well, after several weeks of looking, I finally found a decent drivers side door. Mine was spider cracked around the upper hinge. I have test fitted it and got it body worked and primed. I didn’t get any pics other than this one.
I also got the vintage air unit/block off plate permanently installed. Today, I started body work on the front fenders. I knew the passenger side had a small spot of rust but after I started stripping the fenders they both had rust in them. I decided that I’d rather buy nos fenders and not patch these. Hopefully the new fenders will be here this week
Trey Oney Last edited by bagged01extcab; 03-11-2019 at 07:58 AM. |
03-10-2019, 11:17 PM | #31 |
Great work Trey! Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
03-11-2019, 02:45 PM | #32 |
I'm just glad to be here!
Did not realize you had a build thread on here Trey. Truck is coming along nicely.
Hope to see it out this summer some time!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-11-2019, 06:16 PM | #33 |
I'm digging this one.
03-12-2019, 08:25 AM | #34 |
Thanks everyone! Aggie, I’m hoping to be done with it by the end of May! I’m ready to get it out and enjoy it! Plus I’ve got other projects that I need to Finish! Lol
Got a pic of the vintage air installed I started stripping and body working the ins De of the doors. I am stripping all of the old seam sealer off. After priming, I will seam seal these areas again. On the body work, I’m not trying to get it laser straight, just smooth out the dents. Somebody was hard on the side of the drivers door.
Trey Oney |
