03-20-2019, 09:34 AM | #26 |
Re: Smoothing Firewall
Not to thread jack, but for me, it was faster to cut the wire gutter, and use a full sheet of metal. grind, weld, grind, paint.
Curent build:http://67-72chevytrucks.com/vboard/s...d.php?t=764984 |
03-20-2019, 09:43 AM | #27 |
you all are doing some nice clean work!
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
03-20-2019, 10:58 AM | #28 | |
If I ever do another custom I think this would be the way to go. Looks excellent! I have a question for you. I noticed in the first picture the wall was only cut back to the front edge of the wiring channel, and in the final product you cut it back farther which forced you to cut the doghouse back farther as well. With moving the firewall back that much how did you handle the booster bracket? What other modifications were needed?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
03-20-2019, 12:53 PM | #29 |
here is mine, I still have to do the finish work on it.
03-22-2019, 01:23 PM | #30 | |
06-02-2019, 09:17 AM | #31 |
I hate hand sanding But she's pretty smooth .
Mocking up the 4" cowl induction plenum today .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-14-2019, 02:04 PM | #32 |
That is so bad A$$, keep up the great work. Looks amazing. Cant wait to see that towel induction all completed!
08-14-2019, 02:05 PM | #33 | |
08-14-2019, 03:10 PM | #34 |
Oh good grief. I wish I had not seen this thread as now you guys have me thinking. My 67 has just a bit of rust through on the driver's side in the channel but it's just the lip that is the issue. I have been wondering how to repair and you guys may have convinced me to just cut the whole thing off and make it look smoother anyway.
Couple of question for you smooth cowl guys. 1. Where to you plan on running the wires that were in the channel? 2. Are you all putting vintage A/C in your trucks or are some of you just not installing any heat or air? My truck is a non A/C and I have not yet decided what I will be doing for heat, A/C, or no. I am WAY far from that decision needing to be made but it never hurts to start planning. |
08-14-2019, 03:36 PM | #35 | |
2. I'm using a Vintage air system . At this point what's another $1,000.00
