04-07-2019, 10:05 PM | #26 |
Re: Pitterpat's 84 C20 mild build
If you clean those rust spots up a little and then spray some of this. I have used it, works pretty good. https://www.summitracing.com/oh/part...2002/overview/
On the seat, I can keep an eye out for you. But the only way to get just the seat bottom, is to find a used one. I come across seats occasionally, that the seat covers are still decent.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 04-08-2019 at 07:37 AM. |
04-07-2019, 10:29 PM | #27 |
No picture.
1984 Chevy Custom 20 $2500 work done on engine and transmission 2010/ less than 1000 miles on it since. Here's my mild build thread, http://67-72chevytrucks.com/vboard/s...d.php?t=783971 |
04-07-2019, 10:31 PM | #28 | |
04-07-2019, 10:41 PM | #29 | |
04-08-2019, 07:27 AM | #30 |
There won’t be any smell of tar. And the term “Tar”, is not literally. It’s more of a deadner material. Sometimes the padding gets stuck to the mat, mine was like that up front. Once something wet, like 30 yr old spilled pop that bakes in the sun, the padding will get stuck to it. I had to try and clean some of it off, that’s when it started crumbling, so so some of it got thrown away.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
04-08-2019, 07:38 AM | #31 |
I updated the post. I forgot to add the link for the Rust Transformer
04-08-2019, 07:52 AM | #32 | |
04-08-2019, 08:09 AM | #33 |
I posted a link back on Post #24. Classic Parts $40
04-08-2019, 08:13 AM | #34 |
When I did my truck, I went overboard. I did the Peel & Stick sound mat, Fat Mat. And then I reused the “Deadner Mat” from the factory. Then I put down a foil backed padding, got it from Home Depot. And then the new carpet had jute padding already attached to the back of the carpet.
06-19-2019, 11:11 AM | #35 |
I'm glad that you decided to keep this truck, and welcome!
I have a similarly outfitted truck and am keeping both the CB and the canopy. You may consider some options for a radio that don't require cutting the dash -- it's always nice to keep that intact if it has survived this long. There are options if you want input. TKCR is very well qualified to help with the interior questions you are asking. I also think you are referring to the bituminous sound dampening that was installed at the factory when you say masonite. It may not be in every truck if it was installed as part of an option package -- I don't know. You can leave it in place or remove it and replace it with other products. If it's in your way, there are some products that can be lighter and still be effective, just ask. Good luck and do what you need to do to save the truck. Some times the simple fixes are the best because many vehicles have perished while the owners waited to have enough money and/or time to fix it with nice or new parts. Thanks for telling us about your process. We'd be up for hearing whatever history of it that you care to tell. We pretty much all like to hear when someone saves their dad's truck. |
06-23-2019, 10:00 PM | #36 | |
I don't have much history on this truck. I know my dad bought it used in May of 1995. He had rockers put in like in 2002 and had the motor and transmission rebuilt in the summer of 2010 (for like $2500). He died in the November of 2010, sudden death, he just fell over dead at 85. He lived a good life, was retired with no job for 23 years. Man of the depression. I hope the rain stops in July. I'm trying to get the inside clean (too much humidity to clean and get it to dry). Then put some floor padding down, old cleaner oem pad and a new to me rubber floor covering. This truck was the model without carpet. It has a manual transmission. I'll put the CB back in, I have a used oem GM radio, new speakers and an amp setup to run my smart phone from (like the setup in Sweet Pea). I'm not concerned about it looking bad on the outside but want it to be good on the inside as best I can. Thanks again.
07-23-2019, 09:12 PM | #37 |
Finally got cab cleaned
Tonight I finally had the time and correct weather to get the cab cleaned up. I
used some stuff called Awesome (diluted of course) a small detail brush, sponge couple of small buckets of water and a lot of elbow grease. Is it perfect clean, NO, but it is clean enough. Much cleaner than it was. 1st 2 are b4. Last 3 are after.
07-23-2019, 09:45 PM | #38 |
Lookin good Pat!
07-30-2019, 06:41 PM | #39 |
07-30-2019, 06:50 PM | #40 |
Re: Pitterpat's 84 C20 flooring options
I'm looking to put this felt under the padding of my truck on the floor boards. It's really extra, extra thick landscaping felt. Since I'm not going to put sound deadening because I don't want to peal it off in a year I thought this felt would do the trick, it's about 1/8" thick? Thoughts...
08-22-2019, 03:34 PM | #41 |
Looks like you are making some decent progress. Were you able to get the seat bottom fixed? You seem to have a good project truck on your hands. Good Luck.
Thomas Retired Marine, OIF & OEF Vet. My Project: http://67-72chevytrucks.com/vboard/s...d.php?t=771429 |
09-09-2019, 07:41 PM | #42 |
One big problem. When taking the seats out broke off a bolt, need to get it out. What is the best way? It is the front drivers side bolt, hard to access on the backside.
Pics, bolt readily accessible from in the cab, not so easy on the backside. That is the broken off part on the cab side.
09-09-2019, 07:54 PM | #43 |
Drill it out. Use a smaller drill bit, smaller than the bolt and threads of the weld nut. Once you get most of the bolt drilled out, you might be able to knock the rest out. Then you can tap the hole and it’s ready for a new bolt. Had this happen in my truck. I had 3 out of the 4, break on me. And the 4th, the whole weld nut broke off!
09-09-2019, 08:13 PM | #44 | |
09-09-2019, 08:30 PM | #45 |
Yeah, I did the drill bits in stages. Started small and worked up to a bigger size. Just never got bigger than the bolt itself, so the threads didn’t get damaged. It took awhile just to do one broken bolt.
09-13-2019, 09:13 PM | #46 |
Is the rest of the bolt accessible underneath? Soak it with penetrating oil above and below and put vice grips on the part that sticks out below and twist it on through? I might have it wrong but I think most of the cab floor bolts go through the floor a fair amount.
09-15-2019, 07:02 PM | #47 | |
09-16-2019, 12:43 AM | #48 |
Another option is climb under the truck and break the weld nut off, and the broken bolt with it. Then replace with a conventional bolt and nut.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
09-16-2019, 07:24 AM | #49 |
Not as accessible as I thought, will have to drill out.
09-16-2019, 07:27 AM | #50 |
Not as accessible as I thought, breaking off the weld not may induce a bigger hole. I'll just drill it out and take my chances pf not creating a big hole.
