Old 05-02-2020, 06:04 AM   #26
gmc 2500 4x4
Re: 69 gmc 3/4 4x4 4'' lift question
yup i need a shorter link between pitman and steer arm. old post but thanx for all the input
gmc 2500 4x4 is offline   Reply With Quote
Old 05-03-2020, 06:02 PM   #27
gmc684x4
I am guessing as I have not measured this the difference is from the closed knuckle arm is straight and the open 44 diff arm curls back
when the pitman tie rod arm failed on my 68 I hacked on a 71 up arm onto it
gmc684x4 is offline   Reply With Quote
Old 05-10-2020, 05:53 PM   #28
gmc 2500 4x4
i cut off 1/2" on each end
Old 05-10-2020, 10:02 PM   #29
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Just went through the exact same issue as you. I posted what I did on this other thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=384155
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 06-10-2020, 03:07 PM   #30
gmc684x4
Playing with these trucks i have only found power steering on the 69 and up dana 44 open knuckle diffs your original darg link is shorter and not sure if clocking is different on manual box
I dealt with this on my 69 by swaping to a open knuckle 44 and upgraded at the same time to disc brakes
My 68 i made it as small as i could and lived with it until the old manual box wore out too much i had planed on open 44 front upgrade then my collection of these trucks expanded
I now scrounged a 60 rear and looking for a 60 front for it
