08-30-2019, 08:41 PM | #26 |
Re: compression ratio
72 C10 lwb fleetside -stock 350/350 combo |
08-30-2019, 11:36 PM | #27 |
Wow, you do some awesome clean work, looks sharp! I always was a believer in the cleaner the build the better the results.
I drove my buddy nutz on the last build, He complimented me when I was done. |
08-31-2019, 11:57 AM | #28 |
thanks, keeping it clean means a bunch
I BELIEVE IN JOHN 3:16 |
09-01-2019, 10:34 PM | #29 |
BEST PRICE ON PLUG INDEXING WASHERS.......Info@MHPSonline.com $9.00 A SET
09-02-2019, 10:29 AM | #30 |
Post Whore
Just to be clear it is not the quality of the oil that is the problem. Government regulation of automotive emissions that has caused the API specifications to prevent zinc additives in API approved oils. There are plenty of quality oils with zinc available for use in flat tappet engines they just are not API approved. These oils are made up of the same base stocks as the API oils, but due to the addition of zinc they cannot have an API rating.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-02-2019, 12:24 PM | #31 |
I agree on the oils.
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 09-11-2019 at 06:11 PM. |
09-11-2019, 06:10 PM | #32 |
got my oil scraper made and fitted. anybody want 1 pm me. this stops 99% of oil windage in the bottom end resulting in better fuel milage, longer oil life, less airation of oil and increased hp / torque, and keeping oil in pan for oil pump to pickup a older nascar engine builder turned me on to it.
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 09-11-2019 at 06:16 PM. |
09-11-2019, 09:35 PM | #33 |
Looks like you had to custom grind that. What thickness plate did you use and how do you adapt the gasket to that?
09-11-2019, 11:12 PM | #34 |
Gasket goes between pan and scraper SILICONE OR WEATHER STRIP SEALER GOES BETWEEN SCRAPER AND BLOCK. 18 gauge thickness . Picture is prototyppe part.
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 09-19-2019 at 03:49 PM. |
09-12-2019, 04:02 PM | #35 |
Scraper is made of 18 gauge. $25.00 eaxh
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 09-19-2019 at 03:50 PM. |
09-16-2019, 07:17 AM | #36 | |
laying low
I have always been interested in that LT1 engine. A friend had a Camaro with it. As I remember it thumped pretty good. What do you plan to put it in and with what trans, etc.?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
09-16-2019, 10:29 AM | #37 |
its all lt1 except the heads and carb along with only being 10=1. its going in my lowered 72 lwb c10. 400 turbo
09-24-2019, 03:09 PM | #38 |
My heads ready to go on
09-24-2019, 07:46 PM | #39 |
Ttt
