09-19-2019, 09:34 PM | #1 |
Old member
Re: Daughters 68 step...
Got the rear frame gusset welded in for the gas tank and got the front brakes back together. Got the rear axles back in and hopefully we will have all the rear brakes done and all the fuel lines and brake lines done.
09-19-2019, 10:54 PM | #2 |
Nice work.
I like the cross-member. Good craftsmanship. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
09-20-2019, 08:13 PM | #3 |
Old member
Gas tank is bolted in place along with rear cross bar. Rear brakes done. New hard lines from both wheels to tee and the long hard line from the front to rear is done. Rear end filled with 90/140 gear oil, tomorrow the front brake lines and maybe fuel lines ran.
Good day today I got the winch on the ramp truck fixed also.
10-03-2019, 09:30 PM | #4 |
Wow, great deal! Jealous over here haha
You're making great progress. Looking good! Did you upgrade the LCA u-bolts to the 9/16" ones?
72 C10 lwb fleetside -stock 350/350 combo |
10-04-2019, 09:05 PM | #5 |
Old member
No never have had any issues with the ones installed before.
10-29-2019, 06:47 AM | #6 |
Nice neighbor! That’s pretty cool when things just show up like that.
I really like the pic with your daughter and the steering wheel. Cracks me up
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
10-29-2019, 09:44 AM | #7 | |
Old member
The mini starter is a shelf item at O-Reilly's for a 2000 Caddy Escalade 5.3.with staggered bolt holes.
10-29-2019, 08:19 PM | #8 |
Old member
Just got a shower and supper! I'm tired but I got a bunch done today on the 68.
Cab is ready to lift off Both front fenders and inner fenders off, passenger side front inner fender is gone along with the cab corner on both sides. Hood is off Front grille is off and needs some major fixing! The air passages on both sides need some repair work as well. I guess I'm going to get some welding time in soon. It's going to be interesting for sure.
10-31-2019, 09:57 PM | #9 |
Old member
We got it primmed today! Getting close to starting her up. We tried but the new starter I got was bad. I'll have another one tomorrow!
11-04-2019, 09:18 PM | #10 |
Old member
Got the first coat of fluorescent paint on the needles for the new Tack dash. Also got the first coat of stain on the steering wheel I'm working on. I will lightly sand it down tomorrow and stain it again.
11-09-2019, 06:37 PM | #11 |
Old member
I fixed my buddies sand blaster this week so I started using it for the 68. Been blasting parts all afternoon. It's a slow go. It needs a new glass and a bigger vacuum. It gets real cloudy quickly and you can't see what your working on. I think it needs a better light bulb to. I bought new gloves and media for it. I'm going back tomorrow and take the bulb out and put a new one in it and clean the glass. It has plexi glass in it right now.
But I got a few things done.
11-14-2019, 01:24 AM | #12 |
Old member
Just did a big order from GMC Pauls just now. A bunch of $$$$.$$ and this should just about get the truck back on the road. I hope to find a 67/68 front grille used but not dented up to go on it. Maybe some fenders to if I'm lucky.
11-09-2019, 10:25 PM | #13 |
I am a Referee of life.
Making progress Andy. She'll be cruising it soon. What bed are you using? Step (I hope) or fleet?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-10-2019, 12:31 AM | #14 | |
Old member
We are planning on it staying a step side. We don't have one yet but I have a couple that I'm looking at but nothing bought yet!
11-13-2019, 11:10 PM | #15 |
Old member
A little more progress. The parts have been blasted and primed. The bed of the ramp truck makes for a nice paint surface. I welded up 3 bad spots to day on the cab. The air vents had rust in the bottom of them. I took metal and cut out the rust and welded in pieces. The drivers side floor has a little rust so I welded it up to.
Still have a bunch to do. I ordered a new 3 row aluminum radiator last week off E bay. it came in damaged and they sent me another one and said to keep the other one. No questions on it, can't beat that customer service.
11-14-2019, 07:34 AM | #16 |
No grass growing under Andy's feet !
11-14-2019, 10:19 AM | #17 |
Old member
Thanks,
I have a dead line of Dec 31,2019 to have this truck out of my friends shop. He is selling it and I need it done, well at least drive-able anyway. The bed will not be done by then I'm sure, seeing how I don't have one for it yet. I know I can't cut the LWB bed down before then. I just want it moving under it's own power by 31!
11-14-2019, 10:49 AM | #18 |
Andy, you are a busy guy for sure!! I am sure you will get it done.
Question out of curiosity for a relative newbie to the board, why do you have your posts in bold red? Not an issue for me, just curious if there is a back story.
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
11-14-2019, 11:26 AM | #19 | |
Old member
Just got in the habit of posting this way. I've had people get upset about it to. Has nothing to do with any type of posting about hollering are anything, I didn't even know about that when I started doing it.
11-14-2019, 11:28 AM | #20 |
i was curious about that as well but figured it was just to know where his posts where in a thread, never crossed my mind there might be another reason.
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10” |
11-14-2019, 11:46 AM | #21 |
Old member
Thanks guy's. I try to help whenever I can.
11-14-2019, 11:28 AM | #22 |
That's great!! I totally agree. Nice to see some change! I have read many of your posts and they are very informative. Thanks!
11-14-2019, 02:57 PM | #23 |
Andy , if you were closer I have a grill I would let go . But we are 4 hours apart and shipping would be killer .
11-14-2019, 07:34 PM | #24 |
Old member
Would you meet me part of the way if I was to come that way say to summit racing are some other place?
Could you send me some pictures? I went over today and did some welding and tearing a part the doors to get ready for new parts I ordered last night. I was very pleased with what I got done. My welding is getting better and better but it's still got a way's to go. I got all the door hardware removed from both door's and even got the door latches blasted and blown off. Ready for primer. Got the glass out but have to reseal the drivers side it came out of it's brace. Have to look and see if my old 71 window cranks will work. They look better than these do.
11-14-2019, 08:51 PM | #25 |
Give 'Fastenal' a try....shipping might not be all that bad....
