02-15-2024, 01:19 PM | #1 |
Re: Cheap way to convert my 1968 chevy C10 to 5 lug rear drum or disc
If yours has the coil spring rear, you will need a 71-72 coil rear if you want a direct bolt-in. In 73, they went to all leaf sprung rears. While you can use them (I've done it twice), you will need to swap the trailing arm perches and panhard bar mount onto the replacement axle.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
02-15-2024, 01:23 PM | #2 | |
I might luck out and find a nice one (with posi) and make it worth it.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
02-16-2024, 09:08 AM | #3 | |
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
02-15-2024, 11:52 PM | #4 |
Those are the only differences I can think of. Not sure on driveshaft length or yoke as both I've done got new driveshafts.
02-16-2024, 12:34 AM | #5 |
Just putting in my 2¢. Since the thread started out converting from 6 lug to 5 lug for cheap, the motive gear axles (I thought) were cheap. The differential pinion shaft lock bolt may be broken and you'll need to use an easy out to remove it so you can remove the C clips that hold the axles in. I was all-in for $300ish by the time I bought new bearings, seals, pinion shaft lock bolt, studs, and the axle shafts. I may have been slightly more if I had to buy an extractor kit for the differential pinion shaft lock bolt. I don't know how much they may want for junkyard differentials. I knew I wanted to keep my 308 economy differential, because other than being 6-lug it was what I wanted and the devil I knew.
https://67-72chevytrucks.com/vboard/...d.php?t=824884 https://67-72chevytrucks.com/vboard/...d.php?t=841065 |
