01-08-2020, 03:42 PM | #26 | |
Re: Factory ammeters never work, why?
Great information! I will dig in on my 69 at some point soon to see if the fuses are the issue. I too would greatly prefer a voltmeter but if the amateur would work as good as the one in my 65 I would be perfectly happy. I can always tell right away if the charging system is functioning properly. Steve weim55 Colorado |
01-08-2020, 03:45 PM | #27 | |
01-08-2020, 04:29 PM | #28 |
Does anyone know of a source for these small fuse holders? Both of mine are missing, and I would like to find replacements that are similar.
01-08-2020, 04:33 PM | #29 | |
20' Daredevil (Ret)
01-08-2020, 07:32 PM | #30 | ||
Or, for a functional but not quite as original looking replacement, you could use a couple of waterproof mini ATM fuse holders such as this: https://www.amazon.com/1st-Source-MI.../dp/B00NU9AW42 Quote:
01-08-2020, 11:42 PM | #31 |
70+ ( Old Skool Club )
I put one of T-Bones voltage gauge conversion kits in my truck and it works great. Link below..
http://67-72chevytrucks.com/vboard/s...d.php?t=653967
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-09-2020, 01:27 AM | #32 | |
That temp light gets 12V constant from the cluster and what turns it on is if that wire gets connected to ground. If you take that grounding wire and split it in two there you can connect one end to the temp switch and one to oil. Thanks, KJ
1967 Camaro Emerald Turquoise RSSS 396, Muncie M21, 12 Bolt 3.73 Posi, Hotchkis/QA1 Suspension 1970 CST/10 Dark Olive Short bed Fleetside, 350 SBC, Muncie M21, PS/PB |
01-09-2020, 07:22 AM | #33 |
I've never had one not work. They are handy and useful for what they are meant to do.
01-09-2020, 10:38 AM | #34 | |
For oil pressure, use a T right where it comes out of the block and a pressure switch from a gauge cluster car. Another thought is the bulb test when you turn the key to start.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
01-09-2020, 10:50 AM | #35 | |
I did that 30 year ago. Works great.
Saskatoon, Saskatchewan Canada |
01-09-2020, 11:34 AM | #36 | |
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
01-09-2020, 01:04 PM | #37 |
I cleaned all the grounds in my vehicle, adding 1 or 2 where necessary. The entire electrical system came to life, including the Ammeter gauge.
Use dielectric grease where you have a bolted connection. Pretty simple |
01-09-2020, 04:49 PM | #38 | ||
I agree, the existing TEMP light could be wired up to both temp and oil pressure switches to make it function as a "check gauges" warning light. And yes, a temp switch in the pass side head on a V8 or manifold port and oil switch connected to a Tee fitting where the gauge line goes into the block would do the trick. Wiring it up to the ignition switch (like GM did with the stock TEMP & BRAKE lights) for a bulb check during start-up is a good idea too. When I said earlier, "Adding an oil pressure light into the stock gauge cluster would take a little more work though." I was thinking along the lines of what it would take to cut in a stock looking "window" and fit it with a lens with "OIL" printed on it. |
01-09-2020, 05:05 PM | #39 |
Mine has not moved since I have owned the truck, put a fuse in the drivers side holder as there was none.
Magic.....works like a new one. Very happy. |
01-10-2020, 02:19 AM | #40 |
Location: Herculaneum MO (20 minutes south of St. Louis
Of the 4 trucks the wife & I own only one Ammeter doesn't work. The wiring on that truck has been so butchered I'm surprised anything works.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
01-10-2020, 02:23 AM | #41 |
Who drives around monitoring these gauges constantly?[/QUOTE]
Those who don't want to replace an engine from a severe overheat or a loss of oil pressure
01-10-2020, 05:20 PM | #42 |
Mine works great as well. Slight drop into charge territory with headlights, then gets really bouncy with a/c and gets buried with subwoofer...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
