Old 02-12-2022, 12:29 AM   #26
raylube
raylube's Avatar
Re: divorced np205 transfer case, pinion and u joint angles
Originally Posted by 72cs20 View Post
Ray,
How are those front springs mounted? The stock front brackets and rear shackles? Modifications?
I'm thinking of trying out those front springs, but in a 4 inch lift.
Mine are tuff country springs 72 Chevy 6 inch lift springs ez ride mounted on front stock brackets and rear shackles. Drilled front bracket holes to 3/4 inch and ground out a little from the inside, used greaseable poly bushings from ORD and cut them flush to spring width and then ran steel center bushing from the ORD thru stock brackets into the poly bushing and ground them flush and bolted them with a 5/8 greaseable bolt. Rear of front springs i using 79 k20 shackles drilled to fit stock threaded bushing.
raylube is offline   Reply With Quote
Old 02-12-2022, 12:37 AM   #27
raylube
raylube's Avatar
Ray,
only photos i have.
Old 02-12-2022, 05:50 PM   #28
72cs20
Thank you! This is basically how I envisioned going about it.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
